Whenever I boot my laptop, the grub terminal comes up and I have to input the following three lines to boot into my OS:
linux (hd0,msdos1)/vmlinuz root=/dev/sda1
initrd (hd0,msdos1)/initrd.img
boot
What options should I add to /etc/default/grub so that grub wouldn't need manual input at boot?
This is not something you can change in /etc/default/grub, you need to add a new entry to the GRUB menu. Create a file /etc/grub.d/09_custom with these contents:
#!/bin/sh
exec tail -n +3 $0
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
menuentry 'Ubuntu' {
Make it executable
sudo chmod +x /etc/grub.d/09_custom
and run sudo update-grub. This should add a new entry at the top of the GRUB config file, so when you reboot it should be booted automatically by default.
To reverse the changes, delete 09_custom and re-run sudo update-grub.
fkraiem
  • 12,813
