Possible Duplicate:
How to get Broadcom BCM 43XX Wireless card working
I used 'additional drivers' to install 'Broadcom STA wireless driver' and it returns an error. Within jockey.log it says the following numerous times.
2011-02-14 21:24:06,945 DEBUG: BroadcomWLHandler enabled(): kmod disabled, bcm43xx: blacklisted, b43: blacklisted, b43legacy: blacklisted
After it returns the error the network card will work temporarily until I restart the laptop. When I restart I got to go through the procedure again of trying to activate the driver, returns an error however it works temporarily.
The network card is as follows on a Dell Inspiron 1545:
Broadcom Corporation BCM4312 802.11b/g LP-PHY [14e4:4315] Rev 01
I have been trying to solve this myself for many hours. Any help is appreciated.
I have the same Inspiron 1545 with the 14e4:4315 card, and for me the broadcom-sta driver works without issue. (I've worked really hard to get the non-sta/wl drivers working on all kinds of distros and this particular wlan card just seems to be difficult)
I am guessing that there's some kind of error with the blacklisting of the other available broadcom drivers that ship w/ the kernel (b43, b43xx b43legacy). if you post the output of your error message when you install, lsmod when it's working and lsmod when it's not... that should be a good start.
you should also look at the contents of /etc/modprobe.d/blacklist-bcm43.conf. it should contain the following, which disables the wrong drivers from being loaded:
blacklist b43
blacklist b43legacy
blacklist ssb
blacklist bcm43xx
N.N.
  • 18,589
nathwill
  • 2,643
See: Setup to always load at boot time
WIZARDELF
  • 200
one way to diagnose this would be to run, on a terminal:
dpkg --list firmware-b43-*
look at the package names and statuses (the two leftmost columns read "ii" for installed packages).
I see three b43-related packages in the list of possibilities:
  • firmware-b43-installer
  • firmware-b43-lpphy-installer
  • firmware-b43legacy-installer
For your card (LP-PHY variant) you'd want firmware-b43-lpphy-installer to be installed. I have seen the driver installation tool get it "wrong" and install firmware-b43-installer instead (but that installs a module that doesn't work with the LP-PHY hardware).
If it turns out you don't have firmware-b43-lpphy-installer installed, do so by running this on a terminal:
sudo apt-get install firmware-b43-lpphy-installer
Make sure to have a fallback wired connection handy, if the firmware-b43-lpphy-installer fails, you can remove it:
sudo apt-get remove firmware-b43-lpphy-installer
roadmr
  • 34,802
