I know this question is asked many times before, however with me it is just a bit different I guess.
# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/sda3 224G 5.2G 208G 3% /
udev 1.9G 4.0K 1.9G 1% /dev
tmpfs 777M 260K 777M 1% /run
none 5.0M 0 5.0M 0% /run/lock
none 1.9G 0 1.9G 0% /run/shm
/dev/sda2 90M 88M 0 100% /boot
/dev/sda6 1.9G 514M 1.3G 29% /tmp
My boot partition is full.
Current Kernel:
# uname -r
3.2.0-35-generic
All Kernels:
# dpkg --list | grep linux-image
ii linux-image-3.2.0-32-generic 3.2.0-32.51 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii linux-image-3.2.0-34-generic 3.2.0-34.53 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii linux-image-3.2.0-35-generic 3.2.0-35.55 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
iF linux-image-3.2.0-37-generic 3.2.0-37.58 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
iF linux-image-3.2.0-38-generic 3.2.0-38.60 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
iU linux-image-generic 3.2.0.37.45 Generic Linux kernel image
So I thought of removing the 3.2.0.32-generic kernel with:
# sudo apt-get purge linux-image-3.2.0-32-generic
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
linux-generic : Depends: linux-headers-generic (= 3.2.0.37.45) but 3.2.0.38.46 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
No success.
When I try apt-get -f install it also fails:
# apt-get -f install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
linux-headers-3.2.0-34 linux-headers-3.2.0-35 linux-headers-3.2.0-34-generic linux-headers-3.2.0-35-generic
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
linux-generic linux-image-generic
The following packages will be upgraded:
2 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
5 not fully installed or removed.
Need to get 0 B/4,334 B of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
Setting up initramfs-tools (0.99ubuntu13.1) ...
update-initramfs: deferring update (trigger activated)
Setting up linux-image-3.2.0-37-generic (3.2.0-37.58) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
The link /initrd.img is a dangling linkto /boot/initrd.img-3.2.0-38-generic
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.2.0-37-generic /boot/vmlinuz-3.2.0-37-generic
update-initramfs: Generating /boot/initrd.img-3.2.0-37-generic
gzip: stdout: No space left on device
E: mkinitramfs failure cpio 141 gzip 1
update-initramfs: failed for /boot/initrd.img-3.2.0-37-generic with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-3.2.0-37-generic.postinst line 1010.
dpkg: error processing linux-image-3.2.0-37-generic (--configure):
subprocess installed post-installation script returned error exit status 2
Setting up linux-image-3.2.0-38-generic (3.2.0-38.60) ...
Running depmod.
The link /initrd.img is a dangling linkto /boot/initrd.img-3.2.0-37-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.2.0-38-generic /boot/vmlinuz-3.2.0-38-generic
update-initramfs: Generating /boot/initrd.img-3.2.0-38-generic
update-initramfs: failed for /boot/initrd.img-3.2.0-38-generic with 1.
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-3.2.0-38-generic.postinst line 1010.
dpkg: error processing linux-image-3.2.0-38-generic (--configure):
dpkg: dependency problems prevent configuration of linux-image-generic:
linux-image-generic depends on linux-image-3.2.0-37-generic; however:
Package linux-image-3.2.0-37-generic is not configured yet.
dpkg: error processing linux-image-generic (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-generic:
linux-generic depends on linux-image-generic (= 3.2.0.37.45); however:
Package linux-image-generic is not configured yet.
linux-generic depends on linux-headers-generic (= 3.2.0.37.45); however:
Version of linux-headers-generic on system is 3.2.0.38.46.
dpkg: error processing linux-generic (--configure):
Processing triggers for initramfs-tools ...
No apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
update-initramfs: Generating /boot/initrd.img-3.2.0-35-generic
update-initramfs: failed for /boot/initrd.img-3.2.0-35-generic with 1.
dpkg: error processing initramfs-tools (--configure):
subprocess installed post-installation script returned error exit status 1
linux-image-generic
linux-generic
initramfs-tools
Any help would really be appreciated.
Update: I did:
sudo rm /boot/*-3.2.0-32-generic /boot/*-3.2.0-34-generic
After that the following problem with apt-get -f install:
root@localhost:/# apt-get -f install
linux-generic
linux-generic
1 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
1 not fully installed or removed.
Need to get 0 B/1,722 B of archives.
Version of linux-image-generic on system is 3.2.0.38.46.
linux-generic
