29
I keep getting this error when I try running sudo apt-get install nvidia-current:
Reading package lists... Done
Building dependency tree
 nvidia-current : Depends: xorg-video-abi-11
                  Depends: xserver-xorg-core (>= 2:1.10.99.901)
How do I fix this?
Lucio
  • 19,191
  • 32
  • 112
  • 191
Feders
  • 291
7 Answers7
17
To solve
Try:
sudo apt-get install --fix-broken xorg-video-abi-11 xserver-xorg-core -y
This trick worked for me
Another option will be:
sudo apt-get remove --purge nvidia-* -y
sudo ubuntu-drivers autoinstall
sudo service lightdm restart
Then reboot machine
Appy
sudo apt autoremove
sudo reboot
This is what worked for me!
anjandash
  • 191
Based on the discussion here I fixed this by sudo apt-get purge libnvidia-* followed by sudo ubuntu-drivers autoinstall
I had some leftover packages from a previous nvidia purge that caused issues.
sudo apt autoremove
fixed it for me.
qwr
  • 2,969
This problem arises from an Xorg/nVidia bug where nVidia's driver is incompatible with some of the code in the latest Xorg version. You can try installing the drivers with Software Sources (Additional Drivers tab), or jockey-text in the terminal (which you can learn how to use with a quick Google search or jockey-text --help), or by checking for your drivers at the nVidia website at http://www.geforce.com/drivers (use the Manual Driver Search). Installing the drivers using apt will not work until the issue is fixed sometime in the future.
If you need instructions for installing drivers from nVidia's website, follow the guide here: https://help.ubuntu.com/community/NvidiaManual
Richard
  • 8,588
As noted by 'rajagenupula' user. Special thanks to 'rajagenupula' user
Install older (12.04.1) version of xserver and you can install cuda with with the necessary driver (apt package nvidia-current).
sudo apt-get install xorg-video-abi-11 xserver-xorg-core
vskubriev
  • 905
-1
remove sources.list file.and create new sources.list...
sudo rm /etc/apt/sources.list
Then, type in
sudo software-properties-gtk
enter image description here This will open software-properties-gtk and a newsources.list will be created automatically.
Then change the server to US or to any other server of your choice. You must enable repositories from the new dialog in order to create new sources.list.
Tick all the boxes then click on Revert then click close.
Need to restore default repositories
 sudo apt-get update && sudo apt-get dist-upgrade -y
(it is good practice to backup this file before installing to recover if such things happen)
minigeek
  • 1,071
