I've been trying to install nvidia drivers in ubuntu-20.04 and "sudo ubuntu-drivers install" gives me the following error.
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: nvidia-driver-460 : Depends: libnvidia-gl-460 (= 460.73.01-0ubuntu0.20.04.1) but it is not going to be installed Depends: libnvidia-extra-460 (= 460.73.01-0ubuntu0.20.04.1) but it is not going to be installed Depends: nvidia-compute-utils-460 (= 460.73.01-0ubuntu0.20.04.1) but it is not going to be installed Depends: libnvidia-encode-460 (= 460.73.01-0ubuntu0.20.04.1) but it is not going to be installed Depends: nvidia-utils-460 (= 460.73.01-0ubuntu0.20.04.1) but it is not going to be installed Depends: xserver-xorg-video-nvidia-460 (= 460.73.01-0ubuntu0.20.04.1) but it is not going to be installed Depends: libnvidia-cfg1-460 (= 460.73.01-0ubuntu0.20.04.1) but it is not going to be installed Depends: libnvidia-ifr1-460 (= 460.73.01-0ubuntu0.20.04.1) but it is not going to be installed Depends: libnvidia-fbc1-460 (= 460.73.01-0ubuntu0.20.04.1) but it is not going to be installed Recommends: nvidia-settings but it is not going to be installed Recommends: libnvidia-compute-460:i386 (= 460.73.01-0ubuntu0.20.04.1) Recommends: libnvidia-decode-460:i386 (= 460.73.01-0ubuntu0.20.04.1) Recommends: libnvidia-encode-460:i386 (= 460.73.01-0ubuntu0.20.04.1) Recommends: libnvidia-ifr1-460:i386 (= 460.73.01-0ubuntu0.20.04.1) Recommends: libnvidia-fbc1-460:i386 (= 460.73.01-0ubuntu0.20.04.1) Recommends: libnvidia-gl-460:i386 (= 460.73.01-0ubuntu0.20.04.1) E: Unable to correct problems, you have held broken packages.
I have tried several methods from different forums and no luck.
"sudo apt --fix-broken install" does not solve the problem.
I have tried the solutions from the link given below.
How to solve unmet dependencies when installing Nvidia drivers?
But, "sudo apt-get install --fix-broken xorg-video-abi-11 xserver-xorg-core -y" command also didn't seem to solve the problem. Tried installing from nvidia PPA and the issue persists.
I have attached the system details below.
OS: Ubuntu 20.04.2 LTS x86_64
Host: Nitro AN515-43 V1.10
Kernel: 5.8.0-53-generic
Uptime: 31 mins
Packages: 2293 (dpkg), 13 (snap)
Shell: bash 5.0.17
Resolution: 1920x1080
DE: GNOME
Terminal: gnome-terminal
CPU: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx (8) @ 2.100
GPU: NVIDIA GeForce GTX 1650 Mobile / Max-Q
GPU: AMD ATI 05:00.0 Picasso
Memory: 3275MiB / 5944MiB
This looks like it is similar to an issue that Pop_OS! users were facing recently. System76 has already patched this for Pop_OS! and has alerted Ubuntu developers. I think this will be solved in a couple of weeks- sit tight.
See this: https://www.reddit.com/r/pop_os/comments/n5j8c0/nvidia_driver_4652402_issues/
