So my old computers motherboard died and right in the middle of a windows boot. As you imagine, after buying a new and suitable rig windows 7 will not boot. windows gets to the "windows starting up" animation and restarts. When the computer restarts it goes to the startup repair which says it cannot be repaired. However, with ubuntu installed, all HDD files are accounted for and all components work well. Is there a way for ubuntu to repair the booting process without compromising any files on the HDD? Thanks!
I imagine that since the motherboard died there is some conflict with the Windows installation process which may have left residual files on the hard disk drive which can't be removed with no OS installed.
Accessing Ubuntu on the system doesn't go over the Windows install it uses the hardware to run the OS. You could possible format the Windows partitions on the drives and try to reinstall Windows after you have done that.
- 14,533
i think a recovery image would do the work, all you need is to download it and burn it on a CD and launch the system reparation procedure
- 79
- 4
The correct answer is No. Ubuntu is not designed either to fix Windows errors nor to clear it's trash. The reason why does Ubuntu work is that Linux surpasses Windows in this way: it doesn't bind to chipset model.
There are ways to fix the error, but Ask Ubuntu is not the correct site to ask about them. SuperUser is.
- 13,384
