29
I'm looking for a music player similar to Winamp.
htorque
  • 66,086
7 Answers7
30
There's no software in Linux like the current Winamp. If you want something almost similar, try Audacious, BUT the skined interface ONLY supports winamp 2.x skins. I came from a Winamp environment so I can say this, forget about skins and use the default GTK interface and you'll like it, I know I did :)
Reda Lazri
  • 1,428
19
Audacious is very similar to Winamp and it can even use some of the same skins.
sudo apt-get install audacious
Audacious homepage
Zanna
  • 72,312
Isaiah
  • 60,750
The simplest I've found, that supports WinAMP's 2.x skins is the QMMP.
Since I don't need all the bells and whistles (multi-album, fuzzy sort and search, psychic guessing my mood by the way I'm typing...), just plain old fashioned playlists and "open directory" play (I already have my music organized in my HD...), the QMMP it's all I need: plays all the filetypes I have, can play streams, looks for music lyrics and has the same winAMP appearance key bindings. :) I've tried Audacious, Tomahawk (perhaps not all the time needed to get used to it), and others... And I uninstalled them all: they do much more than I need, so I kept the simplest (still looking for a text-based one! :D). But, for people who needs a lot more, they fill their needs. :)
Manuel
  • 151
Visually, Amarok has nothing in common with winamp, but it has all the functionality and more.
belacqua
  • 23,540
BBetances
  • 245
There is Rhythmbox or VLC.Rythmbox can also be used to sort your music as winamp does.VLC media player,It can also transcode and convert media files, and act as a streaming server over unicast or multicast and IPv4 or IPv6.but doesnt have a good sort function like rythmbox which can sort music like winamp does.
Fusky
  • 405
An addition to Reda Lazri answer
You can even have classic look of Winamp in Audacious.
wget http://gnome-look.org/CONTENT/content-files/64790-Winamp.tar.gz
tar zxvpf 64790-Winamp.tar.gz
mkdir -p ~/.local/share/audacious/Skins
mv Winamp ~/.local/share/audacious/Skins
-1
Try Tomahawk. It's a next generation music player. You can call it social music player. It has got great interface. It's feature rich. You will make it your default music player after testing it. It's my challenge. Tomahawk website
