I've tried to create AP using this and tried to solve my problem
$ iw list
nl80211 not found.
with this, but I still get error when I start make
~/hostapd-2.0/hostapd$ make
../src/drivers/driver_nl80211.c:19:31: fatal error: netlink/genl/genl.h: No such file or directory
compilation terminated.
make: *** [../src/drivers/driver_nl80211.o] Error 1
Any ideas?
I have a Broadcom wireless card.
tikend
  • 702
  • 22
In the link you posted it says:
if this fails with errors like:
driver_nl80211.c:21:31: warning: netlink/genl/genl.h: No such file or directory
driver_nl80211.c:22:33: warning: netlink/genl/family.h: No such file or directory
driver_nl80211.c:23:31: warning: netlink/genl/ctrl.h: No such file or directory
driver_nl80211.c:24:25: warning: netlink/msg.h: No such file or directory
driver_nl80211.c:25:26: warning: netlink/attr.h: No such file or directory
you need to install/update libnl-1.0pre8 (or later). If all goes well and the
compilation finishes, try the minimal hostapd again, see the section Using your
distributions hostapd above for that.
So...
sudo apt-get install libnl1 libnl-dev
then run the build
I skimmed through this and I don't think your card will work for this
to be sure, run this:
lspci | grep -i network
If you have a Broadcom 43.... card this route won't work. See this
EthanB
  • 103
phipsalabim
  • 2,680
