60
I want to resize such an animated GIF file do.gif enter image description here
If I do convert do.gif -resize 24x24\! do-24.gif I get it resized in do-24.gif but not animated enter image description here
How to resize it right way to get the same animation?
zuba
  • 2,423
first run:
then
phipsalabim
  • 2,680
22
I was looking for imagemagick solution as I am familiar with it, but in the end I went with @sam's suggestion of gifsicle. It did just what I wanted, no hassle.
Can optimize resulting file size in so many ways, but I went with just reducing the size and reducing number of colors. Worked like a charm:
Pablo Bianchi
  • 17,371
12
-coalesce + -deconstruct
After -coalesce, you likely want to add a -deconstruct:
The root cause of the problem is that your input GIF was properly minimized: GIF allows the next frame to be just the modified rectangle from the previous one at an offset.
-coalesce then expands all the frames to the original size, which makes the resize work, but it does not re-compress the frames again as your input image: -deconstruct is needed for that!
Using the test data from this answer: How do I create an animated gif from still images (preferably with the command line)? we can see this clearly with identify:
$ identify out-convert.gif | head -n 3
out-convert.gif[0] GIF 1024x1024 1024x1024+0+0 8-bit sRGB 256c 16.7865MiB 0.020u 0:00.019
out-convert.gif[1] GIF 516x516 1024x1024+252+257 8-bit sRGB 256c 16.7865MiB 0.030u 0:00.019
out-convert.gif[2] GIF 515x520 1024x1024+248+257 8-bit sRGB 256c 16.7865MiB 0.030u 0:00.019
$ identify out.gif | head -n 3
out.gif[0] GIF 256x256 256x256+0+0 8-bit sRGB 256c 5.0479MiB 0.000u 0:00.009
out.gif[1] GIF 256x256 256x256+125+128 8-bit sRGB 256c 5.0479MiB 0.000u 0:00.009
out.gif[2] GIF 256x258 256x256+123+128 8-bit sRGB 256c 5.0479MiB 0.000u 0:00.009
$ identify out-coalesce.gif | head -n 3
out-coalesce.gif[0] GIF 256x256 256x256+0+0 8-bit sRGB 256c 1.97683MiB 0.010u 0:00.009
out-coalesce.gif[1] GIF 256x256 256x256+0+0 8-bit sRGB 256c 1.97683MiB 0.010u 0:00.009
out-coalesce.gif[2] GIF 256x256 256x256+0+0 8-bit sRGB 256c 1.97683MiB 0.010u 0:00.009
$ convert out-convert.gif -coalesce -resize 256x -deconstruct out-deconstruct.gif
$ identify out-deconstruct.gif | head -n 3
out-deconstruct.gif[0] GIF 256x256 256x256+0+0 8-bit sRGB 256c 1.87942MiB 0.010u 0:00.010
out-deconstruct.gif[1] GIF 135x135 256x256+60+61 8-bit sRGB 256c 1.87942MiB 0.010u 0:00.010
out-deconstruct.gif[2] GIF 135x136 256x256+59+61 8-bit sRGB 256c 1.87942MiB 0.010u 0:00.010
First, we see how to input file, out-convert.gif, was in fact compressed, since frame 2 is only 516x516 at offset 252+257, while the full sized frame 1 is 1024x1024.
Then, if we compare the three conversions:
  • out.gif: All frames are 256x256 or larger, and huge at about 5MiB, TODO why?
    Visually incorrect, since those approximately 256x256 frames have a non-zero offset, e.g. 125+128 for frame 2!
  • out-coalesce.gif: all frames are 256x256 and have the correct offset 0+0.
    Output looks visually correct, but the output file size is 2.0 MiB, which is larger than out-deconstruct.gif
  • out-deconstruct.gif: compressed frames, final output size 1.9 MiB.
    Not considerably smaller than out-coalesce.gif, but I think this is just because the black ground compresses really well, and it could be very significant in general.
ffmpeg and gifsicle
I also tried out the following commands:
ffmpeg -i out-convert.gif -vf scale=256:-1 out-ffmpeg-small.gif
and both produced an even smaller correctly looking 1.5 MiB output.
See also: How do I create an animated gif from still images (preferably with the command line)?
TODO: why can they make it smaller than convert? Are they just selecting better more minimal diff rectangles, or something else?
Tested in Ubuntu 18.10, ffpmeg 4.0.2-2, ImageMagick 6.9.10-8.
wget https://upload.wikimedia.org/wikipedia/commons/f/f9/STS-132_Liftoff_Space_Shuttle_Atlantis.ogv
ffmpeg -i STS-132_Liftoff_Space_Shuttle_Atlantis.ogv -r 15 -vf scale=512:-1 \
 -ss 00:00:17 -to 00:00:22 STS-132_Liftoff_Space_Shuttle_Atlantis.gif
guntbert
  • 13,475
dieland167
