I'm running windows 7 on my computer (64-bit) and I need to install Ubuntu 12.10 (kernel: 3.5.0-17-generic) virtually.
I've installed VirtualBox from Oracle but I can't find the iso image for this Ubuntu version. Plus, I've read that there are certain procedures in order to install and write C/C++ programs (some people said that installing eclipse was a problem and others said that the GCC compiler was a problem) and that it's not as simple as windows.
So would anyone please tell me where to find the iso image and what steps should I do to successfully start writing parallel programs on Ubuntu.
Rinzwind
  • 309,379
MOMEL
First set up the virtual machine (VM), and download a suitable ISO file from the Ubuntu download page. Personally, I would recommend sticking with a LTS release, in this case Ubuntu 12.04. Mount the ISO file as the VM's optical disk and install from there.
Boot the new VM, login, open a terminal and type:
sudo apt-get install build-essential
That will set up the basic things you need in order to compile and build packages on Ubuntu.
Next, install Eclipse from a downloaded archive or (even easier) from the package.
You asked about Eclipse, but you might also want to give the Netbeans IDE a try, which also offers a similar cross-platform IDE experience.
Werner
  • 276
