i looked and couldn't find an answer to my problem. I am trying to connect to my Logitech Boombox via bluetooth. It recognizes the device, but once it pairs it claims "failed authentication".
Thx, Sebas
I had the same problem running Ubuntu 13.04, with a Logithech Boombox UE. In my case the solution was to edit the /etc/bluetooth/audio.conf file.
Under section [General] add:
Disable=Socket
Enable=Source
This should get the connection working. However, the sound is faltering and I had to add further modifications to the file.
In the same section add:
SCORouting=PCM
AutoConnect=true
Under section [Headset] add:
HFP=false
SBCSources=1
MPEG12Sources=0
This solved the problem for me.
I hope that helps.
After upgrade from 20.04 to 22.04 Boombox didn't connect any more. Installing pipewire-pulse solved the problem.
I have encountered exactly the same problem with Bluetooth 4.99 - I've Googled my eyeballs out on this, posted for help on numerous forums, tried all possible tips & tweaks. Nothing. Logitech support are useless on this.
Somebody, somewhere, must have some ideas on how to fix this!
