84
It's really annoying as I have to unplug the mouse after a suspend to ensure that an occasional bump doesn't wake up the system. I haven't found anything in system settings which could disable this neither by googling around.
pomsky
  • 70,557
17 Answers17
35
I haven't checked the BIOS yet, but I've found a solution!
Short summary: In /proc/acpi/wakeup, you can see which devices are currently enabled to resume from suspend. That list shows names (abbreviated) of so called "Devices". Example "PWRB" means "power button".
If you write device-names to that file, you toggle them between enabled/disabled.
I wrote a small HowTo for disabling wakeup-by-mouse, based on a blog where I found that info.
ntc2
  • 700
Rooker
  • 553
32
The solution I'm using is a udev rule that disables wakeup from a particular USB device. It should be agnostic to which port the device is plugged in to.
Create /etc/udev/rules.d/90-usb-wakeup.rules with the following content (modify idVendor and idProduct as appropriate, see output from lsusb which gives the IDs in the form: vendor:product):
# Disable waking up from Logitech unified receiver
ACTION=="add", SUBSYSTEM=="usb", DRIVERS=="usb", ATTRS{idVendor}=="046d", ATTRS{idProduct}=="c52b", ATTR{power/wakeup}="disabled"
To get it applied without rebooting:
  1. Run:
    sudo udevadm control --reload-rules
  2. Disconnect and reconnect the USB device.
Inspiration comes from https://wiki.archlinux.org/title/udev#Waking_from_suspend_with_USB_device
Wocket
  • 421
30
Thanks to all posters as the mouse wakeup is a major inconvenience and I got my answers here. I wish to add my twist to the solutions as that may help in more cases. I had to disable 3 different items in /proc/acpi/wakeup. My devices: EHC1, EHC2, XHCI. The first 2 are usb2 and the 3rd a usb3 entry. Please note that although the usb transceiver for my mouse is plugged into a usb2 port and nothing is in any usb3 port, the computer will wake on mouse moves until all 3 items are disabled.
$ cat /proc/acpi/wakeup | sort
Device  S-state   Status   Sysfs node
EHC1      S3    *disabled  pci:0000:00:1d.0
EHC2      S3    *disabled  pci:0000:00:1a.0
GLAN      S4    *enabled   pci:0000:08:00.0
USB7      S3    *disabled
WLAN      S3    *disabled  pci:0000:03:00.0
XHCI      S3    *disabled  pci:0000:07:00.0
To have the wakeup items disabled on every startup, you can add something like this to /etc/rc.local ..
echo EHC1 > /proc/acpi/wakeup
echo EHC2 > /proc/acpi/wakeup
echo XHCI > /proc/acpi/wakeup
Test which items need to be disabled - as indicated here - for each of the items that were posted as enabled under cat /proc/acpi/wakeup | sort by running in terminal each of the commands below and then testing if the mouse wakes the system (without the need for restart):
sudo sh -c "echo EHC1 > /proc/acpi/wakeup"
sudo sh -c "echo EHC2 > /proc/acpi/wakeup"
sudo sh -c "echo XHCI > /proc/acpi/wakeup"
(in my case the first one was enough even after testing with other USB ports)
If the /etc/rc.local file doesn't exist
According to this post, run:
printf '%s\n' '#!/bin/bash' 'exit 0' | sudo tee -a /etc/rc.local
sudo chmod +x /etc/rc.local
The file should look something like:
#!/bin/bash
exit 0
Reboot.
If that still doesn't work, it might be that the file /etc/systemd/system/rc-local.service is missing or not properly configured.
Test with
sudo /etc/init.d/rc.local start
and
sudo systemctl status rc-local
Following How to Enable /etc/rc.local with Systemd:
Create the file:
sudo nano /etc/systemd/system/rc-local.service
Then add the following content to it.
[Unit]
 Description=/etc/rc.local Compatibility
 ConditionPathExists=/etc/rc.local
[Service] Type=forking ExecStart=/etc/rc.local start TimeoutSec=0 StandardOutput=tty RemainAfterExit=yes SysVStartPriority=99
[Install] WantedBy=multi-user.target
Save and close the file. To save a file in Nano text editor, press Ctrl+O, then press Enter to confirm. To exit the file, Press Ctrl+X.
Check all is well with no errors with:
sudo systemctl start rc-local.service
sudo systemctl status rc-local.service
Reboot to see changes.
13
This solution works with Ubuntu 15.10, 18.04, 20.04, 22.04
Find your mouse idProduct and idVendor by unpluging and replugging your mouse and searching /sys/bus/usb/devices/* folders. Ignore links with : in the name. For example follow the link for 3-3 but ignore 3-3:1.0
Now try to read the idProduct and idVendor. For example: cat /sys/bus/usb/devices/7-2.3/idProduct => 2000, cat /sys/bus/usb/devices/7-2.3/idVendor => 24ae.
Finally I create a script in /lib/systemd/system-sleep directory, name it mouse-suspend.sh
#!/bin/bash
From lsusb: Bus 007 Device 008: ID 24ae:2000
idProduct=2000 idVendor=24ae
Get sys device path by vendorId and productId
function find_device() { local vendor=$1 local product=$2 vendor_files=( $(egrep --files-with-matches "$vendor" /sys/bus/usb/devices/*/idVendor) ) for file in "${vendor_files[@]}"; do local dir=$(dirname "$file") if grep -q -P "$product" "$dir/idProduct"; then printf "%s\n" "$dir" return fi done }
sysdev=$(find_device $idVendor $idProduct)
if [ ! -r "$sysdev/power/wakeup" ]; then echo $idVendor:$idProduct not found 1>&2 exit 1 fi
case "$1" in enabled|disabled) echo $1 > "$sysdev/power/wakeup" ;; *) echo "$0 enabled -- to enable the wakeup for this device" echo "$0 disabled -- to disable the wakeup for this device" ;; esac
grep --color=auto -H ".*" "$sysdev/power/wakeup" exit 0
If it doesn't work then run sudo chmod +x mouse-suspend.sh && ./mouse-suspend.sh enabled
The above solution (https://askubuntu.com/a/265389/1467620) works, but it is crude and, also it disables the keyboard wake, which is actually useful.
A more granular alternative can be this: First, we start by enumerating the USB devices connected to the system:
lsusb | sort
from here, it’s pretty obvious which one is the mouse:
Bus 002 Device 006: ID 046d:c52b Logitech, Inc. Unifying Receiver
then we proceed with finding where the devices are mapped to:
grep enabled /sys/bus/usb/devices/*/power/wakeup
/sys/bus/usb/devices/2-1.2.6/power/wakeup:enabled /sys/bus/usb/devices/2-1.2.7/power/wakeup:enabled
Finally, to figure out which is which, we use:
dmesg | grep Logitech | grep -o -P "usb.+?\s"
usb 2-1.2.7:
at which point it’s pretty obvious which one needs to be disabled:
sudo sh -c "echo 'disabled' > /sys/bus/usb/devices/2-1.2.7/power/wakeup"
note: every time you need to echo as superuser, sh -c is necessary, or the system will not allow redirecting to a priviliged file.
Then it’s just a matter of suspending the system and verifying that, while the mouse does not wake it, the keyboard will.
this does not survive a system reboot, so either you need to re-run the last command, or add it to your .bashrc or .zshrc.
This is something that has been annoying me on Ubuntu since when I installed 16.04, and probably there forever, I cannot understand why Canonical wouldn’t add this in the System Settings.
Source: https://codetrips.com/2020/03/18/ubuntu-disable-mouse-wake-from-suspend/
ali HOZA
  • 494
Ridiculous, but plug out, plug back in to determine the device code method is the least tedious. So:
  1. find
grep . /sys/bus/usb/devices/*/power/wakeup | grep enabled
figure out the offender using plug-out-plug-in method
  1. disable
sudo sh -c "echo 'disabled' > /sys/bus/usb/devices/YOUR_DEVICE/power/wakeup"
inspired by this blog post
Ufos
  • 469
The solution that worked for me, was got from here.
lsusb | sort
usb 2-1.2.7:
(note: every time you need to echo as superuser, sh -c is necessary, or the system will not allow redirecting to a priviliged file).
This does not survive a system reboot, so either you need to re-run the last command, or add it to your .bashrc or .zshrc
Run command after reboot Run command sudo crontab -e then on a new line add @reboot and the command you want to run after reboot. For example: @reboot sudo sh -c "echo 'disabled' > /sys/bus/usb/devices/3-3/power/wakeup" Save the file and try restarting your computer. Don't add this command to your .bashrc, it may prevent your computer from booting up.
In Kubuntu 19.10 the /etc/rc.local setting stopped working for me. I first noticed this on a Manjaro KDE, and found this solution, that worked there. It also works in Kubuntu 19.10, which may mean there are some changes in newer systems (whether related to the kernel or the Plasma version I don't know).
So:
sort /proc/acpi/wakeup
and look for items that are marked "enabled". Note their names (e.g EHC1,EHC2, NXUC). Then, test which of the commands like below stop the mouse from waking up the PC:
sudo sh -c "echo NXUC > /proc/acpi/wakeup"
Create a folder ~/.bin
mkdir ~/.bin
(If you prefer another location, replace that accordingly in the following files.)
Create a systemd service. In terminal:
nano /etc/systemd/system/wakeup-events.service
With this content:
[Unit]
Description=Disable wakeup events on startup
[Service] Type=oneshot ExecStart=/bin/bash ~/.bin/wakeup-events.sh
Save and enter password.
In terminal:
nano ~/.bin/wakeup-events.sh
with the following content:
#!/bin/bash
# Disable wakeup events
echo EHC1 > /proc/acpi/wakeup echo EHC2 > /proc/acpi/wakeup echo NXUC > /proc/acpi/wakeup
(Replace accordingly: e.g EHC1,EHC2, NXUC).
Don't forget:
sudo systemctl enable wakeup-events
And reboot.
Pablo Bianchi
  • 17,371
cipricus
  • 4,066
  • 47
  • 106
Here is an easier solution. I just wrote the first line:
sudo sh -c "echo disabled > /sys/bus/usb/devices/1-1/power/wakeup"
Now, the USB no:1 doesn't wake up the computer.
Note: by rebooting the system this procedure will reset and will need to be re-run.
Sahin
  • 250
It is possible to use udev rules to set the wakeup setting automatically. For example, I create a new udev rule in /etc/udev/rules.d/99-nowakeup.rules:
ACTION=="add", SUBSYSTEM=="pci|usb", ATTR{power/wakeup}=="enabled", ATTR{power/wakeup}="disabled"
This will prevent any pci or usb device from waking up the system. In my case, that leaves only the power button and RTC timer as ways to wake up.
Here is a way to look at all the ways the system can wake up:
find /sys -type f -name "wakeup" | while read a; do echo "$(cat $a) $a"; done |sort
This is my step-by-step "tutorial" to make it work for you:
  1. Use command cat /proc/acpi/wakeup to show the list of wake up devices
  2. Use command sudo sh -c "echo XXXX >/proc/acpi/wakeup" (replace "XXXX" with your device code) to toggle the device state (enabled/disabled). Go one device at a time and try to suspend your machine and wake it up using the device you want to disable until the deserved device will not be able to wake up the machine. Don't forget to always enable back the devices that you do not want to have disabled.
  3. When you find the right device create on your desktop file "acpi_wakeup" containing following code: #!/bin/sh printf "XXXX" > /proc/acpi/wakeup (don't forget to replace "XXXX" with your device code)
  4. Move or copy the file to folder /etc/init.d/. To copy the file use following command: sudo cp /home/USERNAME/Desktop/acpi_wakeup /etc/init.d/acpi_wakeup (replace "USERNAME" with your actual user name)
  5. Make the file executable: sudo chmod 755 /etc/init.d/acpi_wakeup
  6. Then use 'update-rc.d' to make the required symbolic links automatically in other directories: sudo update-rc.d acpi_wakeup defaults (it shows WARNING: ...missing LSB tags and overrides but it is OK. You don't need to worry about it)
  7. Reboot your computer.
Sources and further reading:
http://www.das-werkstatt.com/forum/werkstatt/viewtopic.php?f=7&t=1985 http://ubuntuforums.org/showthread.php?t=814939&page=3
For me all the above solutions only worked temporarily, that is all the changes got reset after plugging out and in the device or reboot.
Disabling the process using the sudo sh -c "echo XXXX > /proc/acpi/wakeup" command works well until reboot (in my case it was sudo sh -c "echo XHC > /proc/acpi/wakeup"), but none of the solutions above made this setting permanent. Eventually, I found a working solution here: https://unix.stackexchange.com/questions/417956/make-changes-to-proc-acpi-wakeup-permanent
I'm using Ubuntu 20.04.
Iras
  • 181
Short Answer:
ls /sys/bus/usb/devices
get all devices with the same pattern as the devices above, and make a list of command as this:
sudo gedit /etc/rc.local
#!/bin/sh -e
sh -c "echo 'disabled' > /sys/bus/usb/devices/3-1/power/wakeup"
sh -c "echo 'disabled' > /sys/bus/usb/devices/3-2/power/wakeup"
sh -c "echo 'disabled' > /sys/bus/usb/devices/3-7/power/wakeup"
sh -c "echo 'disabled' > /sys/bus/usb/devices/3-10/power/wakeup"
exit 0
Long Descriptive Answer:
Tested in Ubuntu 22.04
A Step-by-Step to the solution:
lsusb | sort
This command lists all usb devices in your computer, it is only informational.
If you don't know the manufactor of your mouse, probably you'll find here.
sudo ls /sys/bus/usb/devices
Using this command you'll see all usb connectors, in my computer I see something like this:
1-0:1.0 3-0:1.0 3-10 3-10:1.1 3-1:1.1 3-7:1.0 4-0:1.0 usb2 usb4 2-0:1.0 3-1 3-10:1.0 3-1:1.0 3-7 3-7:1.1 usb1 usb3
You can see in each connector the status about suspended mode, looking inside /sys/bus/usb/devices/{connector}/power/wakeup, for example:
sudo gedit /sys/bus/usb/devices/3-1/power/wakeup
To make your life easier, instead of opening each file inside each folder, you can use grep to open all wakeup files to show you only files containing enabled.
This command shows you devices that wakeup your computer when suspended.
This command opens each file /power/wakeup inside all folders inside /sys/bus/usb/devices and lists all files containing enabled inside.
grep . /sys/bus/usb/devices/*/power/wakeup | grep disabled
This command shows you devices that doesn't wakeup your computer when suspended.
If you don't know the mouse manufacturer, you can search inside messages about device driver initialization using dmesg command:
sudo dmesg
Try to find something like Mouse, if it is wireless, try to find Wireless etc.
To simplify the search, you can use grep utility:
sudo dmesg | grep Mouse
or
sudo dmesg > drivers_initializations.txt
gedit ./drivers_initializations.txt
search for Mouse
knowing what usb connector the mouse uses, you need to disable the wakeup feacture in /sys/bus/usb/devices/{connector}/power/wakeup
Now open /sys/bus/usb/devices/{connector}/power/wakeup
In my case it was /sys/bus/usb/devices/3-1/power/wakeup
Change enabled to disabled
Suspend your computer and move the mouse, if it works, go to the next step:
Now you need to include this command inside a system startup script, it doesn't work inside .bashrc .profile, because you need to use sudo, and it is before session loading.
I used rc.local script. It is a superuser startup script. It is called after all services are loaded.
Change /etc/rc.local if it exists, if doesn't exist, create it.
add the content:
#!/bin/sh -e
exit 0
Note the example uses connector 3-1, you need to change to your connector.
The script needs to be executable:
Reboot and suspend your computer and check if mouse wakeups your computer, if it still wakeups, rc.local is disabled in your Systemd, go ahead and enable rc.local:
sudo systemctl is-enabled rc-local.service sudo systemctl status rc-local.service
if it is static or disabled, then type the following commands to enable /etc/rc.local with systemd under Linux.
sudo systemctl enable rc-local.service
Reboot and suspend and try again.
danilo
  • 1,865
To disable all USB devices from waking your computer:
Create a udev rule sudo vim /etc/udev/rules.d/99-usb-wakeup.rules
ACTION=="add", SUBSYSTEM=="usb", RUN+="/bin/sh -c 'echo disabled > /sys/bus/usb/devices/%k/power/wakeup'"
There may be a way specific to your hardware, in which case the option may be available through your system's BIOS settings.
Getting to your BIOS menu to change settings is also system specific. Usually you press a key just after rebooting, and the key to press is often displayed on the screen.
However, user138339's answer seems like a more general way to achieve what you need, and you can do this from the running system.
Robie Basak
  • 15,910
This script solved my problem. check it out.
#!/bin/bash
allow only one instance
r=$(pidof -x -o $$ ssmonoff.sh) set -- $r if [ "${#@}" -ge 1 ]; then echo "Script already running. Exit..." exit fi
dbus-monitor --session "type='signal',interface='org.gnome.ScreenSaver'" | ( while read line; do if echo $line | grep "boolean true" &> /dev/null; then xinput --set-prop "Dell Premium USB Optical Mouse" "Device Enabled" "0" xset dpms force off else xinput --set-prop "Dell Premium USB Optical Mouse" "Device Enabled" "1" fi done )
All you have to do is, first, run sudo xinput list, find the given Name of your USB mouse, and put it on the script. Then, save the file as "ssmonoff.sh", make it executable, and set it to run on startup.
yurividal
  • 1,822
Great explanation. I simply added to rc.local the following command
for d in $(cat /proc/apci/wakeup | grep enabled | grep -v PS2K | cut -b -4); do echo $d > /proc/acpi/wakeup ; done
to disable every device than PS2K (keyboard PS2) from wakeup.
Pablo Bianchi
  • 17,371
