I have the following problem: when the computer is in sleep mode (S4 mode) I can wake up it with a simple movement of my USB mouse. I'd like to disable this "fast" wake up, but I have some problems.
In /proc/acpi/wakeup I had this:
Device  S-state   Status   Sysfs node
RP01      S4    *disabled  pci:0000:00:1c.0
PXSX      S4    *disabled
RP02      S4    *disabled
PXSX      S4    *disabled
RP03      S4    *disabled  pci:0000:00:1c.2
PXSX      S4    *disabled  pci:0000:02:00.0
RP04      S4    *disabled
PXSX      S4    *disabled
RP05      S4    *disabled  pci:0000:00:1c.4
PXSX      S4    *disabled  pci:0000:03:00.0
RP06      S4    *disabled
PXSX      S4    *disabled
RP07      S4    *disabled
PXSX      S4    *disabled
RP08      S4    *disabled
PXSX      S4    *disabled
GLAN      S4    *enabled   pci:0000:00:19.0
EHC1      S4    *enabled   pci:0000:00:1d.0
EHC2      S4    *enabled   pci:0000:00:1a.0
XHC       S4    *enabled   pci:0000:00:14.0
HDEF      S4    *disabled  pci:0000:00:1b.0
PEG0      S4    *disabled
PEGP      S4    *disabled
So, following some tutorials online (see here) I typed:
sudo -s
echo EHC1 >/proc/acpi/wakeup
echo EHC2 >/proc/acpi/wakeup
echo XHC >/proc/acpi/wakeup
Now the situation is:
PXSX      S4    *disabled
RP02      S4    *disabled
PXSX      S4    *disabled
RP04      S4    *disabled
PXSX      S4    *disabled
RP06      S4    *disabled
PXSX      S4    *disabled
RP07      S4    *disabled
PXSX      S4    *disabled
RP08      S4    *disabled
PXSX      S4    *disabled
EHC1      S4    *disabled  pci:0000:00:1d.0
EHC2      S4    *disabled  pci:0000:00:1a.0
XHC       S4    *disabled  pci:0000:00:14.0
PEG0      S4    *disabled
PEGP      S4    *disabled
But nothing has changed, a tiny movement of my mouse wakes up my computer. Do you have any solution?
You can fix this in your bios. Get into your bios {F12 or F10 usually does it during boot, possibly the delete key). Turn off "Wake on mouse" it should be in a section called "boot" or "power". I can't give you specifics since all bios are a bit different.
Jason
  • 595
