Every time I am trying to install a package with apt-get install I get this:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
deluge-gtk : Depends: python-notify but it is not going to be installed
fontconfig : Depends: libfontconfig1 (>= 2.8.0) but it is not going to be installed
gstreamer0.10-plugins-good:i386 : Depends: libcaca0:i386 (>= 0.99.beta17-1) but it is not going to be installed
Depends: libflac8:i386 (>= 1.2.1) but it is not going to be installed
ia32-libs-multiarch:i386 : Depends: libasyncns0:i386 but it is not going to be installed
Depends: libfontconfig1:i386 but it is not going to be installed
Depends: libsdl-mixer1.2:i386 but it is not going to be installed
Depends: libsdl-image1.2:i386 but it is not going to be installed
Depends: libsdl-ttf2.0-0:i386 but it is not going to be installed
Depends: libsdl1.2debian:i386 but it is not going to be installed
indicator-application : Depends: libdbusmenu-gtk3-4 (>= 0.4.2) but it is not going to be installed
libappindicator1 : Depends: libdbusmenu-glib4 (>= 0.4.2) but it is not going to be installed
Depends: libdbusmenu-gtk4 (>= 0.4.2) but it is not going to be installed
libappindicator3-1 : Depends: libdbusmenu-glib4 (>= 0.4.2) but it is not going to be installed
libasound2-plugins:i386 : Depends: libpulse0:i386 (>= 1:0.99.1) but it is not going to be installed
libblas3 : Depends: libgfortran3 (>= 4.3) but it is not going to be installed
libcairo2 : Depends: libfontconfig1 (>= 2.8.0) but it is not going to be installed
libcairo2:i386 : Depends: libfontconfig1:i386 (>= 2.8.0) but it is not going to be installed
libcanberra-gtk0:i386 : Depends: libcanberra0:i386 (>= 0.12) but it is not going to be installed
libcanberra-gtk3-module : Depends: libcanberra-gtk3-0 (>= 0.25) but it is not going to be installed
libgd2-xpm : Depends: libfontconfig1 (>= 2.8.0) but it is not going to be installed
libgd2-xpm:i386 : Depends: libfontconfig1:i386 (>= 2.8.0) but it is not going to be installed
libgettextpo0:i386 : Depends: libcroco3:i386 (>= 0.6.2) but it is not going to be installed
libgtk-3-0 : Depends: libfontconfig1 (>= 2.8.0) but it is not going to be installed
libgtk2.0-0 : Depends: libfontconfig1 (>= 2.8.0) but it is not going to be installed
libgtk2.0-0:i386 : Depends: libfontconfig1:i386 (>= 2.8.0) but it is not going to be installed
liblapack3 : Depends: libgfortran3 (>= 4.6) but it is not going to be installed
Breaks: liblapack3gf (< 3.4.1-1)
liblapack3gf : Depends: libgfortran3 (>= 4.6) but it is not going to be installed
libpango1.0-0 : Depends: libfontconfig1 (>= 2.8.0) but it is not going to be installed
libpango1.0-0:i386 : Depends: libfontconfig1:i386 (>= 2.8.0) but it is not going to be installed
libpulse-mainloop-glib0:i386 : Depends: libpulse0:i386 (>= 1:1.1-0ubuntu15.2) but it is not going to be installed
libpulsedsp:i386 : Depends: libpulse0:i386 (>= 1:1.1-0ubuntu15.2) but it is not going to be installed
libqtgui4:i386 : Depends: libfontconfig1:i386 (>= 2.8.0) but it is not going to be installed
librsvg2-common : Depends: librsvg2-2 (= 2.36.1-0ubuntu1) but it is not going to be installed
librsvg2-common:i386 : Depends: librsvg2-2:i386 (= 2.36.1-0ubuntu1) but it is not going to be installed
libsdl-net1.2:i386 : Depends: libsdl1.2debian:i386 (>= 1.2.10-1) but it is not going to be installed
libxft2 : Depends: libfontconfig1 (>= 2.8.0) but it is not going to be installed
libxft2:i386 : Depends: libfontconfig1:i386 (>= 2.8.0) but it is not going to be installed
notification-daemon : Depends: libcanberra-gtk3-0 (>= 0.25) but it is not going to be installed
openssh-client : Depends: libedit2 (>= 2.11-20080614-1) but it is not going to be installed
php5-cli : Depends: libedit2 (>= 2.11-20080614-1) but it is not going to be installed
postgresql-client-9.1 : Depends: libedit2 (>= 2.11-20080614-1) but it is not going to be installed
python-glade2 : Depends: libglade2-0 (>= 1:2.6.1) but it is not going to be installed
python-pygame : Depends: libsdl-image1.2 (>= 1.2.10) but it is not going to be installed
Depends: libsdl-mixer1.2 but it is not going to be installed
Depends: libsdl-ttf2.0-0 but it is not going to be installed
Depends: libsdl1.2debian (>= 1.2.10-1) but it is not going to be installed
Depends: libsmpeg0 but it is not going to be installed
rtorrent : Depends: libtorrent14 but it is not going to be installed
x11-utils : Depends: libfontconfig1 (>= 2.8.0) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
When I run apt-get -f install I get this.
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
bluez-alsa:i386 libgconf-2-4:i386 libatk1.0-0:i386 libqt4-declarative:i386 libgail18:i386 libqt4-qt3support:i386
libunistring0:i386 libcupsimage2:i386 gtk2-engines:i386 libgudev-1.0-0:i386 libcdparanoia0:i386 libcairo-gobject2:i386
libavc1394-0:i386 ssh-import-id libqt4-test:i386 libqt4-script:i386 libqt4-designer:i386 libqt4-network:i386
libqt4-dbus:i386 libproxy1:i386 ibus-gtk:i386 libdbus-glib-1-2:i386 libspeex1:i386 gvfs-libs:i386 libgomp1:i386
libcapi20-3:i386 libibus-1.0-0:i386 libcairo2:i386 libvisual-0.4-0:i386 libcanberra-gtk-module:i386
gtk2-engines-murrine:i386 libwavpack1:i386 libqt4-opengl:i386 libsoup-gnome2.4-1:i386 libglib2.0-0:i386
libmysqlclient18:i386 gstreamer0.10-plugins-good:i386 libqt4-xmlpatterns:i386 librsvg2-common:i386 libdatrie1:i386
libiec61883-0:i386 libgdk-pixbuf2.0-0:i386 libpixman-1-0:i386 libqtcore4:i386 libtheora0:i386 libaa1:i386 libthai0:i386
libao4:i386 libcanberra-gtk0:i386 libqt4-sql:i386 libqt4-svg:i386 libgail-common:i386 liborc-0.4-0:i386
libraw1394-11:i386 libshout3:i386 libdv4:i386 libqt4-xml:i386 gstreamer0.10-x:i386 libgettextpo0:i386 libsdl-net1.2:i386
libjasper1:i386 libvisual-0.4-plugins:i386 libgstreamer-plugins-base0.10-0:i386 libudev0:i386 libgnome-keyring0:i386
gtk2-engines-pixbuf:i386 libqtgui4:i386 libtag1c2a:i386 libssl0.9.8:i386 gtk2-engines-oxygen:i386 libpango1.0-0:i386
gvfs:i386 libqt4-sql-mysql:i386 libqt4-scripttools:i386 libqtwebkit4:i386 libgstreamer0.10-0:i386 libxcb-shm0:i386
gstreamer0.10-plugins-base:i386 libmng1:i386 libgtk2.0-0:i386 glib-networking:i386 libsoup2.4-1:i386 libtag1-vanilla:i386
libjson-glib-1.0-0 librsvg2-2:i386 libavcodec53:i386 libcroco3:i386 libgsm1:i386 libsdl-mixer1.2:i386 libavutil51:i386
libsdl-ttf2.0-0:i386 libsdl-image1.2:i386 libcanberra0:i386 gstreamer0.10-gconf:i386 libmad0:i386 libmikmod2:i386
libmp3lame0:i386 libopenjpeg2:i386 libvpx1:i386 libdirac-encoder0:i386 libschroedinger-1.0-0:i386 libxvidcore4:i386
libx264-123:i386 libva1:i386 libwebp2:i386 libqtdbus4:i386
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
colord freeglut3:i386 gstreamer0.10-gconf:i386 gtk2-engines-pixbuf:i386 ia32-libs ia32-libs-i386:i386 lesstif2:i386
libapache2-mod-php5 libappindicator1 libasyncns0 libasyncns0:i386 libavcodec53:i386 libavutil51:i386 libcaca0
libcaca0:i386 libcairo2 libcairo2:i386 libcanberra-gtk3-0 libcanberra0 libcanberra0:i386 libcolord1 libcroco3
libcroco3:i386 libdbusmenu-glib4 libdbusmenu-gtk3-4 libdbusmenu-gtk4 libdirac-encoder0:i386 libdirectfb-1.2-9
libdirectfb-1.2-9:i386 libedit2 libedit2:i386 libexif12 libexif12:i386 libflac8 libflac8:i386 libfltk1.1:i386
libfontconfig1 libfontconfig1:i386 libgail-common:i386 libgail18:i386 libgd2-xpm libgd2-xpm:i386 libgfortran3 libglade2-0
libgnutls26 libgnutls26:i386 libgphoto2-2 libgphoto2-2:i386 libgphoto2-port0 libgphoto2-port0:i386 libgsm1:i386
libgtk-3-0 libgtk-3-bin libgtk-3-common libgtk2.0-0 libgtk2.0-0:i386 libgusb2 libieee1284-3 libjbig0 libjbig0:i386
libjpeg62 libjpeg62:i386 libjson-glib-1.0-0 libjson0 libjson0:i386 liblapack3gf liblcms2-2 liblzma5 liblzma5:i386
liblzo2-2:i386 libmad0 libmad0:i386 libmikmod2 libmikmod2:i386 libmp3lame0 libmp3lame0:i386 libnotify4 libnspr4
libnspr4:i386 libnspr4-0d:i386 libnss3 libnss3:i386 libnss3-1d libnss3-1d:i386 libonig2 libopenjpeg2:i386 libpam0g
libpam0g:i386 libpango1.0-0 libpango1.0-0:i386 libpopt0 libpopt0:i386 libpulse0 libpulse0:i386 libqdbm14 libqt4-dbus
libqt4-dbus:i386 libqt4-declarative:i386 libqt4-designer:i386 libqt4-network:i386 libqt4-opengl:i386
libqt4-qt3support:i386 libqt4-script:i386 libqt4-scripttools:i386 libqt4-sql:i386 libqt4-sql-mysql:i386 libqt4-svg:i386
libqt4-test:i386 libqt4-xml libqt4-xml:i386 libqt4-xmlpatterns:i386 libqtcore4 libqtcore4:i386 libqtdbus4 libqtdbus4:i386
libqtgui4:i386 librsvg2-2 librsvg2-2:i386 librsvg2-common librsvg2-common:i386 libsane libsane:i386 libsane-common
libsane-extras libsane-extras:i386 libsane-extras-common libschroedinger-1.0-0:i386 libsdl-image1.2 libsdl-image1.2:i386
libsdl-mixer1.2 libsdl-mixer1.2:i386 libsdl-ttf2.0-0 libsdl-ttf2.0-0:i386 libsdl1.2debian libsdl1.2debian:i386
libsigc++-2.0-0c2a libsigc++-2.0-0c2a:i386 libsmpeg0 libsndfile1 libsndfile1:i386 libssh2-1:i386 libsvga1:i386
libsysfs2:i386 libtiff4 libtiff4:i386 libts-0.0-0 libts-0.0-0:i386 libv4l-0 libv4l-0:i386 libv4lconvert0
libv4lconvert0:i386 libva1:i386 libvpx1:i386 libwebp2 libwebp2:i386 libx264-123:i386 libx86-1:i386
libxcb-render-util0:i386 libxft2 libxft2:i386 libxml2 libxml2:i386 libxml2-dev libxmuu1 libxmuu1:i386 libxvidcore4:i386
openssh-blacklist openssh-blacklist-extra openssh-client openssh-server php5-cgi php5-cli php5-common php5-curl php5-gd
php5-imap php5-mcrypt php5-mysql php5-sqlite php5-xsl plymouth python-appindicator python-glade2 python-gtk2
python-notify qdbus sane-utils
Suggested packages:
ia32-libs-gtk ia32-libs-gtk-i386:i386 php-pear libcanberra-gtk0 libcanberra-pulse libcanberra-pulse:i386 libgd-tools
libgd-tools:i386 gphoto2 gphoto2:i386 gtkam gtkam:i386 liblcms2-utils libpam-doc libpam-doc:i386 ttf-baekmuk
ttf-arphic-gbsn00lp ttf-arphic-bsmi00lp ttf-arphic-gkai00mp ttf-arphic-bkai00mp ttf-baekmuk:i386 ttf-arphic-gbsn00lp:i386
ttf-arphic-bsmi00lp:i386 ttf-arphic-gkai00mp:i386 ttf-arphic-bkai00mp:i386 pulseaudio pulseaudio:i386
libqt4-declarative-folderlistmodel:i386 libqt4-declarative-gestures:i386 libqt4-declarative-particles:i386
libqt4-declarative-shaders:i386 qt4-qmlviewer:i386 libqt4-dev:i386 libicu48:i386 qt4-qtconfig:i386 librsvg2-bin
librsvg2-bin:i386 hpoj hplip hpoj:i386 hplip:i386 ssh-askpass libpam-ssh keychain monkeysphere rssh molly-guard
desktop-base plymouth-drm python-gtk2-doc unpaper
Recommended packages:
sane-utils:i386 xml-core:i386 ncurses-term
The following packages will be REMOVED:
ia32-libs-multiarch:i386 libpulse-mainloop-glib0:i386 libpulsedsp:i386
The following NEW packages will be installed:
colord freeglut3:i386 gstreamer0.10-gconf:i386 ia32-libs-i386:i386 lesstif2:i386 libasyncns0 libasyncns0:i386
libavcodec53:i386 libavutil51:i386 libcaca0 libcaca0:i386 libcanberra-gtk3-0 libcanberra0 libcanberra0:i386 libcolord1
libcroco3 libcroco3:i386 libdbusmenu-glib4 libdbusmenu-gtk3-4 libdbusmenu-gtk4 libdirac-encoder0:i386 libdirectfb-1.2-9
libdirectfb-1.2-9:i386 libedit2 libedit2:i386 libexif12 libflac8 libflac8:i386 libfltk1.1:i386 libfontconfig1
libfontconfig1:i386 libgfortran3 libglade2-0 libgphoto2-2 libgphoto2-port0 libgsm1:i386 libgusb2 libieee1284-3 libjbig0
libjbig0:i386 libjpeg62:i386 libjson-glib-1.0-0 libjson0 libjson0:i386 liblcms2-2 liblzma5:i386 liblzo2-2:i386 libmad0
libmad0:i386 libmikmod2 libmikmod2:i386 libmp3lame0:i386 libnotify4 libnspr4-0d:i386 libnss3-1d:i386 libonig2
libopenjpeg2:i386 libpam0g:i386 libpopt0:i386 libpulse0 libpulse0:i386 libqdbm14 libqtdbus4 libqtdbus4:i386 librsvg2-2
librsvg2-2:i386 libsane libsane-extras libsane-extras:i386 libsane-extras-common libschroedinger-1.0-0:i386
libsdl-image1.2 libsdl-image1.2:i386 libsdl-mixer1.2 libsdl-mixer1.2:i386 libsdl-ttf2.0-0 libsdl-ttf2.0-0:i386
libsdl1.2debian libsdl1.2debian:i386 libsigc++-2.0-0c2a:i386 libsmpeg0 libsndfile1 libsndfile1:i386 libssh2-1:i386
libsvga1:i386 libsysfs2:i386 libts-0.0-0 libts-0.0-0:i386 libv4l-0 libv4lconvert0 libva1:i386 libvpx1:i386 libwebp2
libwebp2:i386 libx264-123:i386 libx86-1:i386 libxcb-render-util0:i386 libxmuu1:i386 libxvidcore4:i386 openssh-blacklist
openssh-blacklist-extra python-notify sane-utils
The following packages will be upgraded:
gtk2-engines-pixbuf:i386 ia32-libs libapache2-mod-php5 libappindicator1 libcairo2 libcairo2:i386 libexif12:i386
libgail-common:i386 libgail18:i386 libgd2-xpm libgd2-xpm:i386 libgnutls26 libgnutls26:i386 libgphoto2-2:i386
libgphoto2-port0:i386 libgtk-3-0 libgtk-3-bin libgtk-3-common libgtk2.0-0 libgtk2.0-0:i386 libjpeg62 liblapack3gf
liblzma5 libmp3lame0 libnspr4 libnspr4:i386 libnss3 libnss3:i386 libnss3-1d libpam0g libpango1.0-0 libpango1.0-0:i386
libpopt0 libqt4-dbus libqt4-dbus:i386 libqt4-declarative:i386 libqt4-designer:i386 libqt4-network:i386 libqt4-opengl:i386
libqt4-test:i386 libqt4-xml libqt4-xml:i386 libqt4-xmlpatterns:i386 libqtcore4 libqtcore4:i386 libqtgui4:i386
librsvg2-common librsvg2-common:i386 libsane:i386 libsane-common libsigc++-2.0-0c2a libtiff4 libtiff4:i386 libv4l-0:i386
libv4lconvert0:i386 libxft2 libxft2:i386 libxml2 libxml2:i386 libxml2-dev libxmuu1 openssh-client openssh-server php5-cgi
php5-cli php5-common php5-curl php5-gd php5-imap php5-mcrypt php5-mysql php5-sqlite php5-xsl plymouth python-appindicator
python-glade2 python-gtk2 qdbus
84 upgraded, 103 newly installed, 3 to remove and 733 not upgraded.
4 not fully installed or removed.
Need to get 0 B/86.9 MB of archives.
After this operation, 97.9 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
Extracting templates from packages: 100%
Preconfiguring packages ...
(Reading database ... 123953 files and directories currently installed.)
Unpacking freeglut3:i386 (from .../freeglut3_2.6.0-4_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/freeglut3_2.6.0-4_i386.deb (--unpack):
unable to create `/usr/lib/i386-linux-gnu/libglut.so.3.9.0.dpkg-new' (while processing `./usr/lib/i386-linux-gnu/libglut.so.3.9.0'): Permission denied
No apport report written because MaxReports is reached already
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Unpacking lesstif2:i386 (from .../lesstif2_1%3a0.95.2-1.1_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/lesstif2_1%3a0.95.2-1.1_i386.deb (--unpack):
unable to create `/usr/lib/i386-linux-gnu/libXm.so.2.0.1.dpkg-new' (while processing `./usr/lib/i386-linux-gnu/libXm.so.2.0.1'): Permission denied
Unpacking libasyncns0:i386 (from .../libasyncns0_0.8-4_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/libasyncns0_0.8-4_i386.deb (--unpack):
unable to create `/usr/lib/i386-linux-gnu/libasyncns.so.0.3.1.dpkg-new' (while processing `./usr/lib/i386-linux-gnu/libasyncns.so.0.3.1'): Permission denied
Unpacking libts-0.0-0:i386 (from .../libts-0.0-0_1.0-11_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/libts-0.0-0_1.0-11_i386.deb (--unpack):
error creating directory `./usr/lib/i386-linux-gnu/ts0': Permission denied
Unpacking libdirectfb-1.2-9:i386 (from .../libdirectfb-1.2-9_1.2.10.0-5_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/libdirectfb-1.2-9_1.2.10.0-5_i386.deb (--unpack):
error creating directory `./usr/lib/i386-linux-gnu/directfb-1.2-9': Permission denied
Unpacking libedit2:i386 (from .../libedit2_2.11-20080614-5_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/libedit2_2.11-20080614-5_i386.deb (--unpack):
unable to create `/usr/lib/i386-linux-gnu/libedit.so.2.11.dpkg-new' (while processing `./usr/lib/i386-linux-gnu/libedit.so.2.11'): Permission denied
Preparing to replace libexif12:i386 0.6.20-2ubuntu0.1 (using .../libexif12_0.6.20-3_i386.deb) ...
Unpacking replacement libexif12:i386 ...
dpkg: error processing /var/cache/apt/archives/libexif12_0.6.20-3_i386.deb (--unpack):
unable to create `/usr/lib/i386-linux-gnu/libexif.so.12.3.2.dpkg-new' (while processing `./usr/lib/i386-linux-gnu/libexif.so.12.3.2'): Permission denied
Unpacking libflac8:i386 (from .../libflac8_1.2.1-6_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/libflac8_1.2.1-6_i386.deb (--unpack):
unable to create `/usr/lib/i386-linux-gnu/libFLAC.so.8.2.0.dpkg-new' (while processing `./usr/lib/i386-linux-gnu/libFLAC.so.8.2.0'): Permission denied
Unpacking libfontconfig1:i386 (from .../libfontconfig1_2.9.0-7.1_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/libfontconfig1_2.9.0-7.1_i386.deb (--unpack):
unable to create `/usr/lib/i386-linux-gnu/libfontconfig.so.1.5.0.dpkg-new' (while processing `./usr/lib/i386-linux-gnu/libfontconfig.so.1.5.0'): Permission denied
Unpacking libfontconfig1 (from .../libfontconfig1_2.9.0-7.1_amd64.deb) ...
dpkg: error processing /var/cache/apt/archives/libfontconfig1_2.9.0-7.1_amd64.deb (--unpack):
unable to create `/usr/lib/x86_64-linux-gnu/libfontconfig.so.1.5.0.dpkg-new' (while processing `./usr/lib/x86_64-linux-gnu/libfontconfig.so.1.5.0'): Permission denied
Preparing to replace libxft2:i386 2.2.0-3ubuntu2 (using .../libxft2_2.3.1-1_i386.deb) ...
De-configuring libxft2 ...
Unpacking replacement libxft2:i386 ...
dpkg: error processing /var/cache/apt/archives/libxft2_2.3.1-1_i386.deb (--unpack):
unable to create `/usr/lib/i386-linux-gnu/libXft.so.2.3.1.dpkg-new' (while processing `./usr/lib/i386-linux-gnu/libXft.so.2.3.1'): Permission denied
Preparing to replace libxft2 2.2.0-3ubuntu2 (using .../libxft2_2.3.1-1_amd64.deb) ...
De-configuring libxft2:i386 ...
Unpacking replacement libxft2 ...
dpkg: error processing /var/cache/apt/archives/libxft2_2.3.1-1_amd64.deb (--unpack):
unable to create `/usr/lib/x86_64-linux-gnu/libXft.so.2.3.1.dpkg-new' (while processing `./usr/lib/x86_64-linux-gnu/libXft.so.2.3.1'): Permission denied
I have already tried these solutions:
- update-alternatives: error: alternative path /lib/plymouth/themes/Lmint/Lmint.plymouth doesn't exist
- Cannot install anything through Terminal - apt-get -f install
- apt-get upgrade fails due to dependency issues
I use Linux version 3.2.0-35-generic (buildd@allspice) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #55-Ubuntu SMP Wed Dec 5 17:42:16 UTC 2012
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc nodev,noexec,nosuid 0 0
# / was on /dev/md2 during installation
UUID=9454a058-f582-418b-bbb0-c52a14b2636f / ext4 errors=remount-ro,usrquota 0 1
# /boot was on /dev/md0 during installation
UUID=f3f8ddcc-9906-4896-b9de-beb21689f37e /boot ext2 defaults 0 2
# swap was on /dev/md1 during installation
UUID=d5f380b3-eca3-40ad-9b14-b29d7d603dd8 none swap sw 0 0
I was trying to install deluge when this happened and my server edition
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=12.04
DISTRIB_CODENAME=precise
DISTRIB_DESCRIPTION="Ubuntu 12.04.1 LTS"
# mount
/dev/md2 on / type ext4 (rw,errors=remount-ro,usrquota)
proc on /proc type proc (rw,noexec,nosuid,nodev)
sysfs on /sys type sysfs (rw,noexec,nosuid,nodev)
none on /sys/fs/fuse/connections type fusectl (rw)
none on /sys/kernel/debug type debugfs (rw)
none on /sys/kernel/security type securityfs (rw)
udev on /dev type devtmpfs (rw,mode=0755)
devpts on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
tmpfs on /run type tmpfs (rw,noexec,nosuid,size=10%,mode=0755)
none on /run/lock type tmpfs (rw,noexec,nosuid,nodev,size=5242880)
none on /run/shm type tmpfs (rw,nosuid,nodev)
/dev/md0 on /boot type ext2 (rw)
