I'm trying to upgrade and while doing so, I get the following:
devteam@hephaestusx:~/Projects$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
libboost-python-dev : Depends: libboost-python1.46-dev but it is not installed
E: Unmet dependencies. Try using -f.
devteam@hephaestusx:~/Projects$ apt-get -f install
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
devteam@hephaestusx:~/Projects$ sudo apt-get -f install
Correcting dependencies... Done
The following extra packages will be installed:
libboost-python1.46-dev libboost1.46-dev
Suggested packages:
libboost1.46-doc libboost-date-time1.46-dev libboost-filesystem1.46-dev libboost-graph1.46-dev libboost-iostreams1.46-dev
libboost-math1.46-dev libboost-program-options1.46-dev libboost-random1.46-dev libboost-regex1.46-dev libboost-serialization1.46-dev
libboost-signals1.46-dev libboost-system1.46-dev libboost-test1.46-dev libboost-thread1.46-dev libboost-wave1.46-dev doxygen default-jdk
fop
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 2 not upgraded.
6 not fully installed or removed.
Need to get 0 B/8,151 kB of archives.
After this operation, 80.1 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 226442 files and directories currently installed.)
Unpacking libboost1.46-dev (from .../libboost1.46-dev_1.46.1-5ubuntu2_amd64.deb) ...
dpkg: error processing /var/cache/apt/archives/libboost1.46-dev_1.46.1-5ubuntu2_amd64.deb (--unpack):
trying to overwrite '/usr/include/boost/aligned_storage.hpp', which is also in package libboost1.40-dev 1.40.0-6ubuntu1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Unpacking libboost-python1.46-dev (from .../libboost-python1.46-dev_1.46.1-5ubuntu2_amd64.deb) ...
dpkg: error processing /var/cache/apt/archives/libboost-python1.46-dev_1.46.1-5ubuntu2_amd64.deb (--unpack):
trying to overwrite '/usr/lib/libboost_python-py26.a', which is also in package libboost-python1.40-dev 1.40.0-6ubuntu1
Any idea on how to remedy this?
