As you can see in the screenshot below, the user has managed to run KDE desktop in Unity (or vice versa?)
screenshot
I've already installed kubuntu-desktop package and CompizConfig Settings Manager and also able to switch to KDE desktop separately but couldn't find a way to run both on same screen.
So my question is, how to get this done?
BuZZ-dEE
  • 14,533
Adige72
  • 75
While I totally don't know why one would want this, it's certainly possible. From a standard Ubuntu (with Unity) installation:
  1. Install kubuntu-desktop Install kubuntu-desktop
  2. In a terminal within the Unity desktop, try to run the KDE desktop like this:
    nohup plasma-desktop &
    The nohup somecommand & pattern makes it run in the background and independent of the terminal you're running this in. (specifically, the process spawned isn't a child of terminal in the process tree, but given to the mother of all processes - init.)
  3. optional If you like this and you want to make it permanent you can create a startup script:
    • Create a text file (with for example Gedit) startkde.sh, containing
      #!/bin/bash
      # sleep seems necessary - getting kdeinit I/O errors otherwise
      sleep 3 && /usr/bin/nohup /usr/bin/plasma-desktop &
    • Make the file executable, from Nautilus (file properties), or by running chmod +x startkde.sh
    • Open Startup Applications from the Dash.
    • Add an entry "KDE" and browse to the script.
gertvdijk
  • 69,427
Another easy way to achieve this:
  2. Login with KDE
  3. Run unity in the terminal
Create an autostart entry in KDE with the command unity, if you like.
p.tar
