49
I want to disable NetworkManager entirely, and have my eth0 and wifi connections unmanaged. My eth0 on my main linux box is unmanaged and I have no issues with it, I want to do the same to my other linux boxes all running Ubuntu 12.04 LTS, basically I want to kill Network Manager and never see any trace of it again.
jdthood
  • 12,625
Drassx15
  • 513
6 Answers6
30
First edit /etc/network/interfaces so that the ifup utility can be used to configure eth0 once NetworkManager is gone.
Remove NetworkManager from the system
sudo apt-get purge network-manager
Configure eth0 using ifup.
sudo ifup eth0
jdthood
  • 12,625
16
Gnome:
sudo apt-get remove --purge network-manager-gnome network-manager
KDE:
sudo apt-get remove --purge knetworkmanager network-manager
Unity : lol, Unity.
Seth
  • 59,332
user89599
  • 365
It might be worth it to disable it, configure your alternate setup, and then uninstall it.
Stopping and Disabling NetworkManager | help.ubuntu.com
I did through it may be it will help some one to remove safely Network Manger:
sudo apt-get remove network-manager network-manager-gnome network-manager-pptp network-manager-pptp-gnome
Or
sudo apt-get remove --purge network-manager network-manager-gnome network-manager-pptp network-manager-pptp-gnome
Ramesh Chand
  • 7,564
/etc/resolv.conf and /etc/network/interfaces must both be edited for a manual connection otherwise you will be left without full network capability.
muru
  • 207,228
I don't have 50 rep points to comment, so I'll add some info as an answer that may be helpful. On a Surface Pro 3 with Ubuntu 14.04 installed, Giving this command:
killall -STOP NetworkManager
made a dramatic improvement in RTP-over-wireless streaming applications. NM can be restarted with -CONT parameter. More details here:
Disable / Enable Periodic Wireless Scans
For the SP3 there are other settings required, including net.core.xxx items, and to maintain optimum performance it should remain plugged in. Likely this info applies to other tablets with Ubuntu also.
user.dz
  • 49,176
