I'm installing Ubuntu 12.10 from USB and everything went fine, but on restart it opens the installation files, bacause the USB is there and if a remove it, the laptop acts if there is no OS installed. How to make it to detect that Ubuntu is actually there? When to remove the USB? Please help :( Thanks in advance! :)
It's supposed to tell you explicitly when to remove the USB flash drive, but I think that, unfortunately, that message is not visible 100% of the time.
It's right when the live system shuts down. The best time to remove it is before rebooting. If you've rebooted already and you're in the live system again, then shut down, remove the USB flash drive, and boot your computer.
Assuming there were no problems during the installation, Ubuntu should be installed and working.
If It Still Doesn't Work
If the installation appeared to complete, but booting without the flash drive fails without detecting an operating system, this usually means the GRUB2 boot loader did not successfully install to the Master Boot Record. To fix this, boot from the USB flash drive, select Try Ubuntu (not Install Ubuntu), and reinstall GRUB to the MBR, using any of the techniques on either of these pages:
How can I repair grub? (How to get Ubuntu back after installing Windows?)
(This applies even though the cause of the problem is not a recent Windows installation.)
Then it's necessary to collect more information to troubleshoot the problem. Boot from the USB flash drive, select Try Ubuntu, open a Terminal window by pressing Ctrl+Alt+T. Run:
sudo parted -l
Then select the text from the terminal, copy it to the clipboard, edit your question (or, for readers besides the creator of this question, ask a new question) and paste the text in. You can format it with the <$> tool in the Ask Ubuntu editing toolbar.
- 119,640
