48
Is there an equivalent to the yum "whatprovides" option in apt-get?
For example on CentOS
yum whatprovides /usr/share/gdm/themes/TreeFlower/background.png
Tells me
redhat-logos-4.9.99-11.el5.centos.noarch : CentOS-related icons and pictures.
Repo        : base
Matched from:
Filename    : /usr/share/gdm/themes/TreeFlower/background.png
Can I get similar functionality on the command line in Ubuntu?
Mikel
  • 6,615
This depends on whether the package containing the file is already installed. If so, use dpkg -S filename.
If your intention is to find out which package to install to get a certain file, one option is to use the online packages.ubuntu.com: scroll down to "Search the contents of packages". Make sure that the right distribution is selected. If you're looking for a files irrespective of the path, check the appropriate option.
There is also apt-file. Because this method required updating the files database, however, I prefer the other, instant option.
loevborg
  • 7,414
32
You want the 'apt-file' command.
apt-file search /usr/share/gdm/themes/TreeFlower/background.png
Before using it, you may need to create or update its database by running:
apt-file update
Isn't this the same question as this How do I find the package that provides a file?
I prefer the dpkg -S <filepath> command
Nande
  • 159
wajig whichpkg /usr/share/gdm/themes/TreeFlower/background.png
You'll have to install wajig, which is a frontend to a bunch of utilities related to apt. If you use wajig, you can use all of those tools without having to memorize their names.
