Running cat /proc/sys/kernel/tainted prints the current kernel taint value (in base 10). My understanding is that this value is a bitfield, where each bit indicates the absence or presence of a particular type of taint. You can extract the bits using
python3 -c 'from pprint import pprint; pprint(list(zip(range(50), reversed(bin(int(open("/proc/sys/kernel/tainted").read()))[2:]))))'
I've searched for documentation, but what I've seen only identifies the meaning of bits 0 through 10. For example, http://www.kernel.org/doc/Documentation/sysctl/kernel.txt says:
tainted:
Non-zero if the kernel has been tainted. Numeric values, which can be
ORed together. The letters are seen in "Tainted" line of Oops reports.
1 (P): A module with a non-GPL license has been loaded, this
includes modules with no license.
Set by modutils >= 2.4.9 and module-init-tools.
2 (F): A module was force loaded by insmod -f.
4 (S): Unsafe SMP processors: SMP with CPUs not designed for SMP.
8 (R): A module was forcibly unloaded from the system by rmmod -f.
16 (M): A hardware machine check error occurred on the system.
32 (B): A bad page was discovered on the system.
64 (U): The user has asked that the system be marked "tainted". This
could be because they are running software that directly modifies
the hardware, or for other reasons.
128 (D): The system has died.
256 (A): The ACPI DSDT has been overridden with one supplied by the user
instead of using the one provided by the hardware.
512 (W): A kernel warning has occurred.
1024 (C): A module from drivers/staging was loaded.
2048 (I): The system is working around a severe firmware bug.
4096 (O): An out-of-tree module has been loaded.
8192 (E): An unsigned module has been loaded in a kernel supporting module
signature.
16384 (L): A soft lockup has previously occurred on the system.
32768 (K): The kernel has been live patched.
65536 (X): Auxiliary taint, defined and used by for distros.
131072 (T): The kernel was built with the struct randomization plugin.
I also tried viewing the documentation for the Ubuntu kernel by installing the linux-doc package and opening zless /usr/share/doc/linux-doc/sysctl/kernel.txt.gz, but that still only lists up to 1024.
In my case, I'm running the default PAE kernel (3.2.0-36-generic-pae) on Precise. I am also seeing bit 12 set.
Where is the complete documentation for what the tainted bits mean on Ubuntu kernels?
