I'm confused, I installed this gnome-panel from the Ubuntu Software Center. After that, I can't seem to locate where can I find it. All I see here in the preferences is this Compiz which I find not in favor of my minimalistic taste. I want to know the location where I can have preferences for the Gnome classic (no effect) desktop I set.
Asked
Active
Viewed 1.1k times
You can run the GNOME Panel within Unity by running gnome-panel in a terminal.
If you want a look even more similar to the old GNOME 2:
You can install gnome-session-fallback
and choose GNOME Classic at the login screen.gnome-session-fallbackcan be installed in the Software Center or by running:sudo apt-get update sudo apt-get install gnome-session-fallbackOr you can install the Mate desktop as explained here.
If you just want to have gnome-panel run when you log in, open "Startup Applications" either from the Unity Dash or the menu in Gnome Classic. Click "Add" and put "gnome-panel" in the "Command" field. You don't have to put anything in the "Name" or "Comment" field, they're optional. Click "Add" again.
