Is there any way to remove or configure the following Unity keyboard shortcuts?
I want to make use of these keyboard shortcuts, but I have no use for what they're currently assigned to.
  • Super+M (Music Search)
  • Super+A (Application Search)
  • Super+C (Picture Search)
The keyboard settings utility does not show these anywhere.
Jorge Castro
  • 73,717
namuol
  • 285
You need to remove existing lense keyboard binding.
  • To do so, open a nautilus with with root by executing gksu nautilus
  • Navigate to /usr/share/unity/lenses, Now goto appropriate lenses directory .
  • Inside the folder, there will be a Shortcut field, remove or edit as you want.
    Source
To assign new command for these shortcut, you need to install compizconfig-settings-manager Install compizconfig-settings-manager and use Commands section at top.
More config info - How can I configure Unity?
Web-E
  • 21,716
For Ubuntu 16.04 the steps are different:
Open a terminal
Become root
sudo su -
The lenses are now apparently controlled by scopes
cd /usr/share/unity/scopes
The next command will show the files that contain a shortcut definition
grep -R "Short" *
Make a copy of the existing files (just in case) and verify they copied.
mkdir ~/scopes
cp -rp * ~/scopes
ls -Rl ~/scopes
Remove all the Shortcut entries - if you would rather just disabled some of the shortcuts, then edit the specific files that returned from the previous command.
find ./ -type f -exec sed '/Shortcut/,+1 d' {} \;
Verify all the shortcuts are removed
grep -R "Short" *
This takes effect immediately. The shortcuts do not disappear from Keyboard Shortcuts menu, however.
mcbluefire
