20
I delete files via Nautilus. I then empty the Trash. It shows as empty. However, ~/.local/share/Trash contains 1.5G of stuff. I have a small SSD and so this is highly annoying. Here's what ~/.local/share/Trash shows now.
mfisch@caprica:~/.local/share/Trash$ du -h .
4.0K    ./expunged
988M    ./files/binary-precise-armhf-tar-20130123-6.tar/casper
8.0K    ./files/binary-precise-armhf-tar-20130123-6.tar/.disk
12K ./files/binary-precise-armhf-tar-20130123-6.tar/install
1.5G    ./files
24K ./info
1.5G    .
Why aren't these files removed? Will they be purged later, perhaps by cron?
Edits:
  • I'm already using a fully updated 12.10 image
  • These files were in ~/Downloads, on my SSD drive, they were not on another device.
The permissions look fine. And this morning I have 4 more files in here that never got expunged when I emptied the Trash:
ls -rl ~/.local/share/Trash
total 12
drwx------ 2 mfisch mfisch 4096 Jan 23 20:15 info
drwx------ 3 mfisch mfisch 4096 Jan 23 20:15 files
drwx------ 2 mfisch mfisch 4096 Jan 22 14:01 expunged
ls -rl ~/.local/share/Trash/files/
-rw-rw-r-- 1 mfisch mfisch 313935076 Jan 23 12:33 maguro.img
-rw-rw-r-- 1 mfisch mfisch   4679680 Jan 23 12:30 maguro-boot.img
-rw-rw-r-- 1 mfisch mfisch 179398453 Jan 23 12:35 grouper.img.gz
-rw-rw-r-- 1 mfisch mfisch   5244928 Jan 23 12:33 grouper-boot.img
drwxr-xr-x 5 mfisch mfisch      4096 Jan 23 16:05 binary-precise-armhf-tar-20130123-6.tar
So here's an update. I rm -rf'd .local/share/Trash last week. It didn't come back until I rebooted a couple days later. Since then, it's been well behaved. So I think this means that this is a bug rather than a useful question. I'll file a bug if it happens again because I should be able to trust that trash is doing what it is supposed to do. Here's what it looks like now:
mfisch@caprica:~/.local/share/Trash$ du .
4   ./expunged
4   ./files
4   ./info
16  .
mfisch
  • 3,693
"Trash" is sort of superimposed into Linux because our file systems don't work like NTFS which people expect coming from Windows. Personally, I think best practice is to avoid using a garbage cache and things are either all the way there or all the way gone.
In your situation, if I wanted to keep using it, I would make a bash script on my desktop to the effect of:
rm -rf "path to trash folder"
and run it after I "emptied" the trash.
wjandrea
  • 14,504
user89599
  • 365
Did you enable TRIM on your SSD, if not it would be good idea to do so. TRIM improves your computer's compatibility with the Linux OS and it also increases the SSD's lifespan.
Here's how you do it.
