I usually delete files permanently using Shift+Delete.
But once I accidentally sent an item to the Trash can using just Delete and got this error:
"Trash can touched maximum limit/Empty Trash can manually".
But when I view the contents of the Trash can, it appears that it is actually empty: no files, no hidden files and no used space.
My OS is Kubuntu 12.04.1 LTS.
adi
  • 865
  • 30
The notice is based on the metadata file and not the actual content of the trash folder. Check for this file for the cache size (if you want):
~/.local/share/Trash/metadata
2 methods of getting rid of the notice:
  • Remove it and the system will create a new file when you delete a file as a user.
  • You can also edit the file and change size={number} to size=0
Rinzwind
  • 309,379
