-1
Possible Duplicate:
How do I resolve unmet dependencies?
When I try to update or install new packages it pops up an eror message telling me that the package catalog needs repaired, I click repair and than it tells me it was unable to repair.
initramfs-tools: Depends: initramfs-tools-bin (>= 0.99ubuntu13) but 0.99ubuntu13.1 is installed Depends: klibc-utils (>= 1.5.9-1) but 1.5.25-1ubuntu2 is installed Depends: busybox-initramfs (>= 1:1.13.3-1ubuntu5) but 1:1.18.5-1ubuntu4.1 is installed Depends: udev (>= 147~-5) but 175-0ubuntu9.2 is installed Depends: findutils (>= 4.2.24) but 4.4.2-4ubuntu1 is installed Depends: util-linux (> 2.15~rc1) but 2.20.1-1ubuntu3 is installed
and when performed 'sudo apt-get -f install' the output
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following extra packages will be installed:
  initramfs-tools
The following packages will be upgraded:
  initramfs-tools
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
3 not fully installed or removed.
Need to get 0 B/49.0 kB of archives.
After this operation, 1,024 B of additional disk space will be used.
Do you want to continue [Y/n]? y
dpkg: dependency problems prevent configuration of initramfs-tools:
 initramfs-tools depends on initramfs-tools-bin (<< 0.99ubuntu13.1~); however:
  Version of initramfs-tools-bin on system is 0.99ubuntu13.1.
dpkg: error processing initramfs-tools (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
                          dpkg: dependency problems prevent configuration of plymouth:
 plymouth depends on initramfs-tools; however:
  Package initramfs-tools is not configured yet.
dpkg: error processing plymouth (--configure):
                          dpkg: dependency problems prevent configuration of plymouth-label:
 plymouth-label depends on plymouth (= 0.8.2-2ubuntu31); however:
  Package plymouth is not configured yet.
dpkg: error processing plymouth-label (--configure):
 initramfs-tools
 plymouth
 plymouth-label
and I tried Maintenance commands - AptGet/Howto - Community Help Wiki but it didn't work.
How can I fix this error?
Kulfy
  • 18,154
CodiE
Check if you have enough free space in /boot. In my case I got rid of exactly the same error message by purging old kernel images via Synaptic Package Manager.
