But when i use Windows 7 it is so silent i barely hear any sound from fan. I'm using standard graphics card drivers released by Ati i'm not using additional video drivers which are open source. Windows 7 is so hardware efficient it is running so efficiently on 5 years old laptop & Linux is struggling to run efficiently on it. I thought Linux's were more efficient than Windows but Ubuntu proved me wrong.
Don't suggest me to use Ubuntu 12.10 because graphics drivers are not available for my Ati 45xx graphics card.
Don't tell me switch to older Ubuntu versions i faced the same problems there also.
My BIOS version is A13 which is the latest & is up-to-date.
Looks like a known bug still present , see - https://bugs.launchpad.net/ubuntu/+source/linux/+bug/748080
Try doing following as mentioned in comments, see if it improves any thing
echo low | sudo tee /sys/class/drm/card0/device/power_profile
Here is a way to install fglrx drivers for legacy version.
How to install amd catalyst legacy drivers in ubuntu 12.10
This link was posted as answer of What is the correct way to install proprietary ATI Catalyst Video Drivers (fglrx) directly from AMD?
Web-E
  • 21,716
i was also having the almost same probem with amd with ubuntu 13.04 i installed the gnome shell extension "Radeon Power Profile Manager " which has the option to put the profile in low mode which a bit reduces the temp , but that's for gnome shell only with open source drivers
link to the extension : https://extensions.gnome.org/extension/356/radeon-power-profile-manager/
