12
I have this problem: I'm used to compile and run .c files with CodeBlocks. If I do that from my Desktop (ext4 partition) it works without problems, but doing this from my secondary hard drive (NTFS partition) makes CodeBlocks to say permission denied while running a .c file.
I have read it's because of the partition type is it correct? But I don't know how to solve it. I tried to edit fstab (sudo gedit /etc/fstab) adding this line:
/dev/sda /media/Dati ntfs user,exec 0 1
but after rebooting Ubuntu I had a warning on boot about a problem mounting a drive, that's because I set KDE to auto mount my Dati drive on boot.
So I should auto mount my NTFS drive with execute permission? How can I do that?
muru
  • 207,228
Frank
  • 1,583
Follow these steps to make a NTFS partition executable:
  1. Open a terminal and type sudo blkid -c /dev/null
    This command allow you to identify your NTFS drive and your UUID number. Example:
    /dev/sdb1: LABEL="my_label" UUID="xxx" TYPE="ntfs"
  2. Open the /etc/fstab file from terminal typing sudo -H gedit /etc/fstab
  3. Don’t edit the existing lines, but add new one at the end like this example:
    UUID=xxx /media/my_label ntfs-3g defaults,auto,uid=1000,gid=1000,umask=002 0 0
    NOTE: Replace the UUID number and the mounting point /media/my_label according to your situation!
  4. Save the file and close the text editor.
  5. Enter the next command in the terminal: sudo mount -a
  6. And restart Ubuntu. Done
Now, every time you mount your NTFS partition, you will be able to run executable files.
muru
  • 207,228
Frank
  • 1,583
I tried above solutions but didn’t work for me. This worked.
UUID=xxx /media/ny ntfs-3g auto,users,permissions,exec,big_writes,windows_names 0 0
Ref - https://wiki.archlinux.org/index.php/NTFS-3G
Ganesh
  • 191
