I have recently purchased a Novatech nFinity N1410 laptop and am having problems with the wireless, which
sudo lshw -C network
tells me is Centrino Wireless-N 2230 and using the iwlwifi driver.
The problem is that after the device has been suspended, I am not able to get the wireless working again without a restart. The network indicator states that the wireless disabled by hardware switch.
Though Fn+F2 is meant to be the wireless switch,
xev
tells me that the system doesn't see it as anything at all when I press this hardware combination. Also, though the brightness up/down buttons work fine, the volume up/down buttons do not work either.
What can I do to fix this? I am running Ubuntu 12.10 with all available updates installed.
Mochan
  • 1,708
5 Answers5
I've been looking into buying one of these and have been looking for potential problems, looks like your solution can be found in the novatech forums:
  1. Simply created a new file called brcm.sh
  2. Inserted the below code and save:
    #!/bin/bash
    # Simple bash script to fix resume from suspend issues...
    # Place this script in /etc/pm/sleep.d/
    # then chmod +x /etc/pm/sleep.d/brcm.sh
    case $1 in
      hibernate)
        /sbin/modprobe -r brcm80211
      suspend)
      resume)
        /sbin/modprobe brcm80211
      thaw)
    esac
  3. Placed it in /etc/pm/sleep.d/
  4. Made it executable:
    sudo chmod +x /etc/pm/sleep.d/brcm.sh
Source: http://forum.novatech.co.uk/showthread.php?25709-nFinity-N1411-solved-Ubuntu-12-10-install-and-wifi-wake-from-suspend&p=331411
Eric Carvalho
  • 55,453
i had the same problem and i have no hardware switch just F2 for disabling and enabling wifi instead of using unblock wifi try blocking it using
$ sudo rfkill block wifi
i know it sounds crazy but it worked for me and i'm using a dell laptop and we have the same wifi driver after using unblock
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
after using block
Soft blocked: yes
Hard blocked: no
and to remove the soft block just click on the wifi button on the top right corner of your unity desktop and select Enable Wi-Fi
Vishnu667
  • 131
Try this solution
You can use this command to unblock all wireless devices: From the terminal,
sudo rfkill unblock all
You can also run
rfkill list all
to find out whether it is a software block or rather a hardware block
You may have to reinstall the driver
sudo modprobe iwlwifi
If wireless begins working again, you can create scripts in /etc/pm to do this each time you suspend and resume.
gksudo gedit /etc/pm/config.d/modules
...and added the line...
SUSPEND_MODULES="iwlwifi"
Ringtail
  • 16,285
For my dell D630 notebook, the following has worked, to solve the "Soft blocked: yes" wifi after a suspend:
sudo rmmod wl
sudo modprobe wl
After typing this the wifi has returned. No reboot required anymore, a success!
Seems re-initializing the kernel module solves the problem.
(wl, the wireless kernel module, I have a broadcom wifi, the kernel module name might differ)
You might try this at /etc/pm/sleep.d/brcm.sh when the system is returning from a suspend as noted by John White.
I have an ubuntu 12.04 64 bit.
-1
Try installing wicd sudo apt-get install wicd and completely remove network-manager sudo apt-get remove --purge network-manager-gnome network-manager it fixed all Wi-fi problems on my Acer C720 including yours.
XperianX
  • 339
