10
I'm on a general energy saving mission. I've finally swapped my old CRT monitor for a LCD, so the next step it to optimise the PC power usage. It's using an AMD 64 X2 4600+ CPU which I know can trottle down, but seems to be running at a constant 2.4GHz.
A while back I heard about Granola. I've installed it, but when I try to run it (via sudo granola) I get
granola[10568]: Error opening scaling governor file '/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor' in read mode
granola[10568]: Is cpufreq enabled in this kernel and do you have a CPU which supports DVFS?
granola[10568]: Can't manage DVFS for any CPUs
I'm happy to use other applications if Granola is not optimal or viable, but am not looking to invest in new hardware just now.
Running kernel 2.6.35-25-generic
steevc
  • 887
You Can Use Jupiter
Jupiter is an applet which allows you to switch between maximum and high performance and power saving mode, change the resolution and orientation, enable or disable the bluetooth, touchpad, WiFi and so on.
You can install by adding the ppa ppa:webupd8team/jupiter and installing jupiter from the software center.
Lincity
  • 25,749
I'm not sure what the exact sequence of events was, but I just noticed that granola is running now. I know I tried installing cpufreqd and powernowd, but either caused Granola to be uninstalled. It may just be that the PC needed to restart.
It would be nice if the app showed more details about how often the CPU is being throttled and to what speed. I can see current speed with
cat /proc/cpuinfo
and to time at each speed with
cat /sys/devices/system/cpu/cpu0/cpufreq/stats/time_in_state
I'm assuming both cores run at the same speed. That shows speeds from 1-2.4GHz with most time spent at the lower speeds. I have a whole-house power meter. I'll see if that can tell me the difference the speed makes.
Update: I was too quick to celebrate. Today it's not working. I looked in /var/log/messages and found this for yesterday
Feb  4 07:50:20 zaphod kernel: [    0.560856] powernow-k8: Found 1 AMD Athlon(tm) 64 X2 Dual Core Processor 4600+ (2 cpu cores) (version 2.20.00)
Feb  4 07:50:20 zaphod kernel: [    0.560910] powernow-k8:    0 : fid 0x10 (2400 MHz), vid 0xc
Feb  4 07:50:20 zaphod kernel: [    0.560912] powernow-k8:    1 : fid 0xe (2200 MHz), vid 0xe
Feb  4 07:50:20 zaphod kernel: [    0.560914] powernow-k8:    2 : fid 0xc (2000 MHz), vid 0x10
Feb  4 07:50:20 zaphod kernel: [    0.560917] powernow-k8:    3 : fid 0xa (1800 MHz), vid 0x10
Feb  4 07:50:20 zaphod kernel: [    0.560919] powernow-k8:    4 : fid 0x2 (1000 MHz), vid 0x12
For today there is just the first of those lines. That suggests something went wrong, but where do I see the errors? Restarted and it was ok.
steevc
  • 887
This page offers some suggestions: http://grano.la/help/install.php
Have you verified that those cpufreq files and folders mentioned in the error file exist?
Also, ensure that DVFS is enabled in the BIOS http://grano.la/help/wiki/doku.php?id=bios
Also have you tried just adding the "CPU Frequency scaling monitor" applet in Gnome? I believe the cpufreq module is part of the kernel now, so it just works for me.
Simon B
  • 1,296
I installed granola and found the GUI to be pretty but lacking any really useful information. I would much prefer to see what it is actually doing in terms of frequency scaling than how many trees it is saving!
I have now opted for powernowd (you have to uninstall granola first, since you can only have one power management daemon runnin at once. Otherwise the two could be pulling the CPU frequency in opposite directions).You can install powernowd from the software center.
This appears to be lightweight and gets the job done. I can monitor the current CPU frequency on each core by adding the "CPU frequency scaling monitor" applet to my Gnome panel (I think it comes pre-installed with the Ubuntu 10.10).
Now my Intel Q6600 (4 x 2.4GHz) spends most of its time at 4 x 1.6GHz.
andrew.46
  • 39,359
Jon Brett
  • 379
