I created a custom shortcut Ctrl+Alt+T that calls x-terminal-emulator. For some reason, it does not work (nothing happens when hitting the mapping).
When I remove the shortcut, the built-in Launch terminal shortcut (which is also set to the same mapping) opens the terminal window as expected.
The problem is when I restart my session after deleting the shortcut, it is recreated in the custom shortcut window.
Do you have any idea why this shortcut is always recreated automatically after restarting a session? Do you have any idea how to fix this?
I can't find a configuration file in my home that contains the x-terminal-emulator string. I am running 12.04 Desktop.
