Just installed a ssd drive with 16.04 how can i point Ubuntu to the old drive for home folder with all my files?
Asked
Active
Viewed 1.1k times
First use lsblk to find the device id of your old drive. It sill be something like sdb or sda. Now mount it at /home for eg:
sudo mount /dev/sdb1 /home
Now using sudo blkid, note the uuid of your old drive (UUID will be a very long string such as an0246cg-2kb2-6e8f-ae26-2355691e325b)
Open /etc/fstab in your favorite editor, for eg: sudo nano /etc/fstab and add the following at the end.
UUID=<noted number from above> /home ext4 defaults 0 2
Make sure to edit, if necessary, the ext4 to match the file system in your old drive.
Ron
- 20,938
