Good Day,
I want to give Ubuntu more HDD space so I tried to create a new partition then merge it with my Ubuntu's. Windows is unable to create more that 5 partitions I decided to uninstall then re-install Ubuntu.
I used a recovery disk to uninstall Ubuntu. I went into the command prompt and ran "bootrec /fixboot" the following message appeared "The volume does not contain a recognized file system. Please make sure that all the required file system drivers are loaded and that the volume is not corrupted." "Bootrec /fixmbr" ran without any problems.
When I turned on the computer it booted into Windows 7
Question - Do I still need to run "bootrec /fixboot" or can I delete the Ubuntu Partition and run Windows 7 without any problems?
bootrec /fixboot only fixes files (more precisely bootmgr) on the Windows partition. It should work without /fixboot.
More important is the fixed mbr. But if your Windows boots with the normal Windows boot loader (not grub), everything is fine.
lub
  • 1,589
