14
I downloaded http://qt-project.org/downloads
Qt5 Libary for Linux 64bit
The library format is .run
But if I try to open it, I'll get the following error
sh ./qt.run
./qt.run: 1: ./qt.run: cannot open @8: No such file
./qt.run: 1: ./qt.run: ELF: not found
./qt.run: 1: ./qt.run: Syntax error: word unexpected (expecting ")")
and then it produces a garbage file.
RolandiXor
  • 51,797
Maik Klein
  • 1,321
You have to make the file executable and then simply execute it.
Type the following commands in the terminal:
chmod u+x qt.run
./qt.run
bender
  • 1,854
