Possible Duplicate:
How to install software or upgrade from old unsupported release?
How can I fix a 404 Error using the Ubuntu archives?
While trying to upgrade, I got this error. Has anyone seen it before? Please advise me on what to do! Thank you!
W:Failed to fetch http://extras.ubuntu.com/ubuntu/dists/natty/main/source/Sources.gz  404  Not Found
W:Failed to fetch http://extras.ubuntu.com/ubuntu/dists/natty/main/binary-i386/Packages.gz  404  Not Found
E:Some index files failed to download, they have been ignored, or old ones used instead.
These are 'extras' for Ubuntu 11.04 ('Natty').
This release reached end-of-life recently, and is no longer supported for security and other updates.
See: Ubuntu 11.04 (Natty Narwhal) reaches end-of-life on October 28, 2012
If you need to be using a long-term-support release, you should be using 12.04 LTS (or possibly 10.04 LTS on very old equipment).
If you are currently using 11.10 (Oneiric):
Is there any reason you still have Natty-specific resources in your setup? Otherwise, removing these two lines will solve this error.
If you are still on 11.04 (Natty):
You should not be attempting to upgrade directly to 12.04, but instead first upgrade to 11.10.
Note: As you have not already done so, and may not be up-to-date, it would be better to do a clean install of 12.04 LTS instead (after backing-up all settings and user data). Any issues you may have with upgrading from 11.04 are not supported, as 11.04 is no longer supported.
david6
  • 14,528
  • 38
  • 46
