14
Possible Duplicate:
I can’t update 12.04 LTS
I tried to install several package before and it happened before, actually Iþm getting this for
sudo apt-get install libvte-dev
and this is the tail...
0 upgraded, 56 newly installed, 0 to remove and 0 not upgraded.
Need to get 10.9 MB/14.9 MB of archives.
After this operation, 62.2 MB of additional disk space will be used.
Do you want to continue [Y/n]? Y
Get:1 http://cz.archive.ubuntu.com/ubuntu/ precise/main zlib1g-dev amd64 1:1.2.3.4.dfsg-3ubuntu4 [165 kB]
Media change: please insert the disc labeled
 'Ubuntu 12.04.1 LTS _Precise Pangolin_ - Release amd64 (20120823.1)'
in the drive '/media/cdrom/' and press enter
I'm online. Where is the problem?
Note: I installed ubuntu from USB stick - I have no CD
Betlista
  • 411
If you have an internet connection, you can safely comment out the line starting with deb cdrom: .... in the file /etc/apt/sources.list. You can edit this file with the command:
sudo gedit /etc/apt/sources.list
and simply prepend this line with the #-sign so that it looks something like this:
# deb cdrom:[Ubuntu 12.10 _Quantal Quetzal_ - Release amd64 (20121017.5)]/ quantal main restricted
Save the file and don't forget to run
sudo apt-get update
bender
  • 1,854
