16
When editing files like sudoers, I want to use emacs instead of nano. So I ran this command
sudo update-alternatives --config editor
And I selected emacs. The only issue is I like emacs in no window mode (the -nw flag) and I've aliased emacs as emacs='emacs -nw' so that I can use no window mode in normal use, but I don't know how to get my default editor to be in no window mode.
In other words, I need to get the command sudo visudo and similar commands that open up editors to open the file with emacs -nw. How can I do this? I'm on Ubuntu 12.04.
gsgx
  • 552
Add the following to your ~/.bashrc file (or the config file for your shell if it is not Bash).
export EDITOR="emacs -nw"
This should set (and export) an env variable setting your default editor as Emacs in non-graphical mode.
haziz
  • 3,067
Create a script that starts emacs with -nw flag, e.g. /usr/local/bin/emacs-nw.
#!/bin/sh
emacs -nw "$@"
Install it with update-alternatives --install.
sudo update-alternatives --install /usr/bin/editor editor /usr/local/bin/emacs-nw 2
Configure editor to be your new script.
sudo update-alternatives --set editor /usr/local/bin/emacs-nw
McNisse
  • 1,933
I have following setting in my ~/.bashrc
export EDITOR="emacsclient -t -a=\"\""
This will first try to connect emacs daemon server if it is already started, otherwise start daemon server first then connect again.
Similarly, I have following setting in my ~/.gitconfig
[core]
    editor = emacsclient -t -a=\\\"\\\"
