I am running Kubuntu 12.10 64bit. I am trying to get a bash script to execute when I am disconnected from the network. I created a file in the folder /etc/network/if-down.d/ called test which has a single line:
zenity --info --text="network down!"
I can execute this script without any issues; typing /etc/network/if-down.d/test into my terminal causes a message box to pop up saying "network down!". When I disconnect from my wifi network via the network manager, nothing happens. Unplugging my wifi usb dongle does not cause the message box to appear either. My only guess is that for what ever reason scripts in /etc/network/if-down.d/ are not being executed. Adding #!/bin/bash as the first line didn't work either.
EDIT: 2013-01-02
I had some issues using gertvdijk's answer (old edits and comments getting mixed up) which are now sorted out. Running zenity with su and DISPLAY=:0 solved my problem.
drdrez
  • 373
If you're using Network Manager (opposed to the command-line /etc/network/interfaces file), you should use the Network Manager dispatcher scripts instead.
Simply place your script in the /etc/NetworkManager/dispatcher.d/ directory, similar to the if-down.d approach. Scripting with Network Manager dispatcher scripts is rather easy and I suggest to read this (basic) example based as posted on the Arch Wiki:
#!/bin/sh
INTERFACE=$1  # The interface which is brought up or down
STATUS=$2     # The new state of the interface
USERNAME=gert # ENTER YOUR USERNAME HERE
case "$STATUS" in
    'up') # $INTERFACE is up
    # you could do something here...
    'down') # $INTERFACE is down
    # Check for other active interfaces and only act on all down
    if [ ! `nm-tool|grep State|cut -f2 -d' '` = "connected" ]; then
        /bin/su -l ${USERNAME} -c 'DISPLAY=:0 /usr/bin/zenity --info --text="all network interfaces down"'
    fi
esac
For acting on a specific network, see this answer.
And make sure to restart Network Manager to pick up with this new script.
sudo service network-manager restart
gertvdijk
  • 69,427
I tried this out (on 10.04) and have the same issue. It looks like the script does not know which display to display the dialog on.
Try replacing your line by:
DISPLAY=0:0 zenity --info --text="network down!"
(If you have several displays, you may need something more subtle.)
loxo
  • 379
The other answers are great - probably even better than this one, but, as usual, there's another way to do it - this time without needing system utilities or elevated permissions (sudo).
My system runs kubuntu 12.04, so this code will probably work on your system. It should also work on gnome 2.x as well except that the autostart script goes in a different place.
I had a similar issue where I wanted to know when my computer went offline (because my notebook seems to do this occasionally by disabling wifi by itself and I often didn't notice the little red x in the taskbar.)
What I did was to add a small (executable) script to the ~/.kde/Autostart directory which runs my main script every time KDE starts (this takes care of it having a display and keyboard to use):
#!/bin/bash
if [ -x "$HOME/bin/offline_alert" ] ; then
  offline_alert &
fi
The main script, offline_alert, tests to see if I'm offline using ping with a few retries to avoid false alarms and then generates a pop-up using yad (same as zenity, only way enhanced!) and plays a sound. In between testing for changes in online status, it sleeps so it doesn't use too many resources.
If you run it manually from the command line, etc., it checks to see if it is already running and gives you the option to end it.
The code that tests for offline is in the "offline" function, so it can easily be modified without affecting the rest of the script.
The images, icons, and sound it uses are hard coded, so you'd have to substitute your own. I found a cool wifi offline icon on the web.
It creates a log file which you may or may not want.
The script is setup to use notifications, but the code is commented out because the notifications went away too quickly and seemed more of a nuisance than a help.
This is just another way to do it and maybe someone will find the code useful.
Joe
Joe
  • 2,012
