I have a Compaq Presario C700 which has a GRUB multi-boot for Ubuntu 12.10 (32 bit), Ubuntu 10.10 and Windows Vista. This machine is always run by mains electricity rather than by battery as I have hooked it up to my 40" TV. It works like a dream in every respect - except one... If I want to watch a video longer than 10 minutes the power-saving blank screen associated with an inactive keyboard/mouse kicks in; a tap of a key or movement of the mouse restores the display instantly. This is irritating and happens for both 10.10 and 12.10. I have tried the following remedies:
- Checked BIOS for advanced setting that might override Ubuntu commands (no such settings exist)
- Changed system Power settings in 12.10 to 'Don't suspend' (battery or plugged in) for inactive behavior and 'Do nothing' when lid is closed for battery and plugged in. "When power is critically low" has been left with the default blank (although this is not really applicable as the unit is always plugged in).
- Changed system Brightness and Lock settings in 12.10 to 'Turn screen off when inactive for:' to Never. Lock is set to 'Off' and 'Turns screen off' option is greyed out. Brightness is set to maximum and 'Dim screen to save power' is unchecked.
- I have checked out the Displays, Keyboard and mouse settings but there is nothing of relevance there.
- I have seen a similar question on Ask Ubuntu but there were no satisfactory permanent solutions for Ubuntu 12.10 “Turn screen off when inactive for: Never” still turns off as
- sudo xset s offdid not work
- sudo xset s 0 0did work within the session (screensaver timeout = 0; cycle =0 ) but on rebooting from cold- xset qshowed a reverted screensaver timeout = 600; cycle = 600 - so it is not an acceptable solution. (Yes - I do have administrator rights!)
One annoying facet of this problem is that the screen goes blank after 10 minutes of inactivity and it takes 10 (very long) minutes to find out if a solution has worked so any trial and error method of solving this has a significant time penalty for me.
Has anyone experienced and successfully overcome this problem?
