I have a dell inspiron 15z (ultrabook) with two drives, one HDD (500 Go) and one SSD (32 Go) managed by a kind of raid 0 array called intel smart response, and Windows 8 already installed.
Dell allows the bios to disable the secure boot mode, but when I launch the ubuntu installer from a live cd, the install does not recognize any drive.
So I tried, as read on the web, to deactivate Intel smart response from the GUI in Windows 8, and to set the SATA mode to AHCI or to ATA (I tried both).
In both cases, it does not work. I just want to use ubuntu and remove (if possible) Windows.
What can I do? Should I format the bios and reinstall it from scratch?
gertvdijk
  • 69,427
thank you all for your replies, the problem was that the Ubuntu installer did not recognize any disk while the Intel Smart Response was on.
But it was easy after all, I was being a bit stupid : I just needed to find the Intel Smart Response GUI in Windows 8 and to turn everything off inside.
Then I could install any Linux distribution.
Thanks again.
There is actually a simple answer to this question, if you mean to completely remove Windows 8 and keep only Ubuntu. After installing Ubuntu on the USB through PenDriveLinux, reboot with the USB attached to your computer. Now, restart and keep pressing F2, F12, or delete while it is booting to access the Dell startup menu. There should be an "exit" or "Boot" option. On one of those, if you see anything related to "USB", just select that. The Ubuntu load button should show, and after a while it will show a menu. Click "Install Ubuntu". After going through a few steps, you will see one which says "Installation Type". If you are sure you want to take out Windows and keep Ubuntu, select "Erase disk and install Ubuntu". Continue.
