Possible Duplicate:
Whats the simplest way to edit and add files to “/var/www”?
I'm fairly new to Ubuntu, and Linux in particular. I want to use Ubuntu for web development mostly, so I went ahead and installed LAMP manually using this guide. Everything works good. Apache, PHP, MySQL are all working perfectly fine, but there's this permission issue.
My files are going to be in /var/www, but I don't have permissions to this directory. How would I make it so that I have the permissions to edit, view (also in browser), delete, and create files in this directory?
Note that I am not hosting a server, so security is not an issue. I will be managing my project locally.
Rafay
  • 123
Instead of making your files world open, you can use ACL to give one of your groups the permissions to the whole subtree. ACL are more flexible than regular permissions in my opinion and a default rule can be used to apply to new files/directories.
sudo apt-get install acl
To use, you have the command setfacl and getfacl
man acl will explain the concept and man setfacl will give you all the use ptions but here is a suggestion:
sudo setfacl -Rm d:g:<your-user-main-group>:rwX,g:<your-user-main-group>:rwX /var/www
Will give your main group rw permissions and x on the directories (to enter them).
-R: recursive
-m: modify existing rule (the actual permissions)
d:g:<...>:rwX = default part for new files, group permissions
g:<...>:rwX   = applied to the existing files/directories
rwX           = read, write and change directory allowed (rwx will allow file execute too)
If you prefer, instead of using your main group (if you have other users for example), you can create a group (webdev for example) and use it:
sudo addgroup webdev
sudo adduser your-user webdev
and use webdev group in the acl instead of your-user-main-group
Obs: you can also use ACLs with users (u:) or others (other:) instead of groups.
laurent
  • 6,899
