23
I'd like to automate the process of locally backing up my Gmail account, and am looking for a solution that:
  • can be scheduled to run in the background
  • does not cause messages to be marked as read
What resources are available for doing this in Ubuntu?
Braiam
  • 69,112
ændrük
  • 78,496
offlineimap Install offlineimap is a popular solution for this.
Enable IMAP in GMail
(Google's instructions)
  1. Sign in to Gmail.
  2. Click Settings at the top of any Gmail page.
  3. Click Forwarding and POP/IMAP.
  4. Select Enable IMAP.
  5. Configure your IMAP client and click Save Changes.
Setup offlineimap
After you install it create a .offlineimaprc
[general]
accounts = GMail
maxsyncaccounts = 3
[Account GMail] localrepository = Local remoterepository = Remote autorefresh = 10 #refresh every 10 minutes quick = 5 #Quick-syncs do not update if the only changes were to IMAP flags
[Repository Local] type = Maildir localfolders = /whatever/directory
[Repository Remote] type = IMAP remotehost = imap.gmail.com remoteuser = your_username@gmail.com remotepass = your_password ssl = yes maxconnections = 1
#Setting realdelete = yes will Really Delete email from the server. #Otherwise "deleting" a message will just remove any labels and #retain the message in the All Mail folder. realdelete = no
Then you need to run offlineimap.
Automating offlineimap with cron
In some cases having offlineimap running all the time can consume large amounts of memory, especially if you have a large mailbox, so you can add an offlineimap check into cron to just check it and then exit, here's a daily backup:
 @daily offlineimap -u Noninteractive.Basic
Backing up offlineimap
The files will be in whatever you define in the localfolders line as a Maildir. You can back this up using whatever backup method you use:
References
Jorge Castro
  • 73,717
An alternative would be to use fetchmail. fetchmail can use both pop3s and imap4s to access Google. There are online tutorials on how to configure.
user4124
  • 9,241
I have done some research on HOW TO backup an IMAP account comparing different available tools w.r.t. a set of wanted features and concerns. As a result, I used offlineimap, as already suggested above. (My saved comparison still may be useful to see a bigger picture.) Also, I summed up (answering a related question) some points concerning the architecture of such a solution for backing up an IMAP account and storing it in Git.
