I am trying to enable touchpad multitouch/scrolling in Ubuntu 12.04 on my Dell Inspiron 5720 (17R). By default after installation it had the following settings (xinput results):
⎡ Virtual core pointer                      id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ Logitech Unifying Device. Wireless PID:101b   id=11   [slave  pointer  (2)]
⎜   ↳ PS/2 Generic Mouse                        id=14   [slave  pointer  (2)]
So I followed this tutorial: https://askubuntu.com/a/211755/113496
After installing the package stated there using install.sh here is installation log:
konnigun@konnigun-Inspiron-5720:/usr/src/psmouse-alps-dst-0.4$ sudo bash ./install.sh
MAIN: Driver source files by Dave Turvene. Install script by garyF.
MAIN: Removing previous versions of psmouse-alps-dst...
-------- Uninstall Beginning --------
Module:  psmouse
Version: alps-dst-0.4
Kernel:  3.2.0-35-generic (x86_64)
Status: Before uninstall, this module version was ACTIVE on this kernel.
psmouse.ko:
 - Uninstallation
   - Deleting from: /lib/modules/3.2.0-35-generic/updates/dkms/
 - Original module
   - No original module was found for this module on this kernel.
   - Use the dkms install command to reinstall any previous module version.
depmod.........
DKMS: uninstall completed.
Deleting module version: alps-dst-0.4
completely from the DKMS tree.
Done.
MAIN: Building current driver from source files...
Creating symlink /var/lib/dkms/psmouse/alps-dst-0.4/source ->
DKMS: add completed.
Kernel preparation unnecessary for this kernel.  Skipping...
Building module:
cleaning build area....
make KERNELRELEASE=3.2.0-35-generic -C /lib/modules/3.2.0-35-generic/build M=/var/lib/dkms/psmouse/alps-dst-0.4/build/src psmouse.ko......
DKMS: build completed.
MAIN: Installing the driver
psmouse:
Running module version sanity check.
 - Original module
 - Installation
   - Installing to /lib/modules/3.2.0-35-generic/updates/dkms/
depmod....
DKMS: install completed.
rmmod psmouse, wait=no
insmod /lib/modules/3.2.0-35-generic/updates/dkms/psmouse.ko
MAIN: Done installing. Go to System Settings > Mouse and Touchpad to configure :-)
My touchpad got totally disabled. I mean, it doesnt work at all. But xinput now gives the following:
⎜   ↳ PS/2 Mouse                                id=14   [slave  pointer  (2)]
⎜   ↳ AlpsPS/2 ALPS GlidePoint                  id=15   [slave  pointer  (2)]
But touchpad doesn't work. What can I do to fix it? Thanks alot =)
UPD:
After updating Kernel from 3.2 to 3.5 it began working but in a very strange way: only scrolling and Fn+F3 began to work. Scrolling is working very strange. Nothing else works (I mean no two-finger scrolling and stuff like that). So basically I have a usual touchpad behavior now + scrolling.
Chelios
  • 245
Okay, after spending half of a day solving this puzzle here is what I got: Neither v0.4 or v1.0 installation from http://www.dahetral.com/public-download worked for me, touchpad just wasn't working it all.
So I upgraded kernel from 3.2 to 3.5 by doing this:
sudo apt-get install linux
Which actually installed the following packages:
- linux-header-3.50-030500 - linux-header-3.50-030500-generic - linux-image-3.50-030500-generic
After that I tried and reinstalled 0.4 version (using 1.0 version right now though) and it started working. What is strange: I didn't even reboot in new kernel, I installed driver with new kernel installed, than I purged it and everything works. Can't quite understand why it's like that.
Also I wanna say thanks to alfC for reminding me to check touchpad settings in system menu, totally forgot bout that.
Chelios
  • 245
