I have a dual boot and a I configured windows to use UTC with a registry fix as explained in here: Clock time is off on dual boot
Now, I need to come back to localtime again, and I have no idea about how to edit the windows' registry to make it use local time again.
On my Windows 7 machine, the default is for HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\TimeZoneInformation\RealTimeIsUniversal to not exist. So, here are Windows instructions:
Hold down the Windows logo key and press R. There, type regedit. Click OK and if you're using Vista or newer, acknowledge the UAC warning.
Now, in the left pane, there is a tree view. Under Computer, there will be some things called HKEY_SOMETHING_OR_OTHER. You should click the + next to HKEY_LOCAL_MACHINE. Then, you should click the + next to SYSTEM to get ino HKEY_LOCAL_MACHINE\SYSTEM. Now, expand CurrentControlSet, then inside it, Control, and then TimeZoneInformation. Now, right-click the entry for RealTimeIsUniversal and select the option to delete it. Alternatively, you could set it's value to 0.
nanofarad
  • 20,906
