(A related question found here.)
I've been used 11.04, now 12.04 LTS, and if there is solution, I don't want to upgrade from that LTS.
The first problem is, that the network-manager/networking behaves wrong:
- when I'm on battery, the WiFi connects (the mobile broadband also), but no network can be accessed, like when something timing out. If I connect the AC charger, it immediately starts working.
- usually just lists the options: enable network, enable wireless network, enable mobile broadband, edit networks & network information, there are no lists of available networks, etc...
Bluetooth:
- The Bluetooth is always turns on on start up, but when I turn it off on another 12.04 LTS, it remembers, and doesn't turn on on start up.
Conclusion: this laptop is no longer mobile, it requires AC charger to connect to networks.
What I have tried to solve the main problem?
- Upgrade the network-manager, to the latest daily PPA version: 0.9.6.0~git201208071622.5714-0~pkg562~precise1
- replace wireless driver with b43, but is was not supported (How do I get a Broadcom BCM4313 wireless card working?)
- upgrade the BIOS. Now I have version A05, the latest is A06, but I couldn't because I haven't found the HDR file in Dell's repos (there is no system_bios_ven_0x1028_dev_0x0470_version_A06 dir), and I could't generate if from the Windows executable (wine /writehdrfile /nopause now doesn't work) - original tutorial is here
- install some Dell software/firmware:
ii dell-dup 1.1.3-0ubuntu2 A firmware-tools plugin for Dell DUP images ii firmware-addon-dell 2.2.9-0ubuntu1 A firmware-tools plugin to handle BIOS/Firmware for Dell systems
Information:
sudo lshw -class network
*-network
description: Ethernet interface
product: AR8132 Fast Ethernet
vendor: Atheros Communications Inc.
physical id: 0
bus info: pci@0000:02:00.0
logical name: eth0
version: c0
serial: 5c:26:0a:46:bd:49
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vpd bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=atl1c driverversion=1.0.1.0-NAPI firmware=N/A latency=0 link=no multicast=yes port=twisted pair
resources: irq:43 memory:d0200000-d023ffff ioport:a000(size=128)
*-network
description: Wireless interface
product: BCM4313 802.11b/g/n Wireless LAN Controller
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:03:00.0
logical name: eth1
version: 01
serial: 88:25:2c:e4:55:83
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=wl0 driverversion=5.100.82.38 ip=172.27.1.13 latency=0 multicast=yes wireless=IEEE 802.11
resources: irq:17 memory:d0300000-d0303fff
*-network DISABLED
physical id: 2
logical name: wwan0
serial: 02:80:37:ec:02:00
capabilities: ethernet physical
configuration: broadcast=yes driver=cdc_ether driverversion=22-Aug-2005 firmware=Mobile Broadband Network Device link=no multicast=yes
sudo lspci -vnn -d 14e4:
03:00.0 Network controller [0280]: Broadcom Corporation BCM4313 802.11b/g/n Wireless LAN Controller [14e4:4727] (rev 01)
Subsystem: Broadcom Corporation Device [14e4:051a]
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at d0300000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Capabilities: [58] Vendor Specific Information: Len=78
Capabilities: [48] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [d0] Express Endpoint, MSI 00
Capabilities: [100] #14e4
Kernel driver in use: wl
Kernel modules: wl, bcma, brcmsmac
sudo smbios-sys-info
Libsmbios version: 2.2.28 Product Name: Inspiron 1120 Vendor: Dell Inc. BIOS Version: A05 System ID: 0x0470
lcpci
00:00.0 Host bridge: Advanced Micro Devices [AMD] RS880 Host Bridge 00:01.0 PCI bridge: Dell Device 9602 00:04.0 PCI bridge: Advanced Micro Devices [AMD] RS780/RS880 PCI to PCI bridge (PCIE port 0) 00:05.0 PCI bridge: Advanced Micro Devices [AMD] RS780/RS880 PCI to PCI bridge (PCIE port 1) 00:11.0 SATA controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode] 00:12.0 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI0 Controller 00:12.2 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB EHCI Controller 00:13.0 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI0 Controller 00:13.2 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB EHCI Controller 00:14.0 SMBus: Advanced Micro Devices [AMD] nee ATI SBx00 SMBus Controller (rev 42) 00:14.2 Audio device: Advanced Micro Devices [AMD] nee ATI SBx00 Azalia (Intel HDA) (rev 40) 00:14.3 ISA bridge: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 LPC host controller (rev 40) 00:14.4 PCI bridge: Advanced Micro Devices [AMD] nee ATI SBx00 PCI to PCI Bridge (rev 40) 00:18.0 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor HyperTransport Configuration 00:18.1 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Address Map 00:18.2 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor DRAM Controller 00:18.3 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Miscellaneous Control 00:18.4 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Link Control 01:05.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI RS880M [Mobility Radeon HD 4200 Series] 01:05.1 Audio device: Advanced Micro Devices [AMD] nee ATI RS880 HDMI Audio [Radeon HD 4200 Series] 02:00.0 Ethernet controller: Atheros Communications Inc. AR8132 Fast Ethernet (rev c0) 03:00.0 Network controller: Broadcom Corporation BCM4313 802.11b/g/n Wireless LAN Controller (rev 01)
lsmod
Module Size Used by dm_crypt 23125 1 joydev 17693 0 snd_hda_codec_hdmi 32474 1 snd_hda_codec_realtek 224173 1 snd_hda_intel 33773 4 snd_hda_codec 127706 3 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel snd_hwdep 17764 1 snd_hda_codec dell_wmi 12681 0 snd_pcm 97275 3 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec sparse_keymap 13890 1 dell_wmi snd_seq_midi 13324 0 snd_rawmidi 30748 1 snd_seq_midi snd_seq_midi_event 14899 1 snd_seq_midi dell_laptop 18119 0 snd_seq 61929 2 snd_seq_midi,snd_seq_midi_event dcdbas 14490 1 dell_laptop snd_timer 29990 2 snd_pcm,snd_seq snd_seq_device 14540 3 snd_seq_midi,snd_rawmidi,snd_seq fglrx 3264017 69 uvcvideo 72627 0 videodev 98259 1 uvcvideo ums_realtek 18248 0 cdc_ether 13536 0 usbnet 26212 1 cdc_ether psmouse 97485 0 v4l2_compat_ioctl32 17128 1 videodev snd 79041 18 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device uas 18180 0 cdc_wdm 17581 0 cdc_acm 26821 0 serio_raw 13211 0 edac_core 53746 0 soundcore 15091 1 snd sp5100_tco 13791 0 k10temp 13166 0 edac_mce_amd 23709 0 snd_page_alloc 18529 2 snd_hda_intel,snd_pcm i2c_piix4 13301 0 btusb 18332 1 shpchp 37277 0 rfcomm 47604 0 bnep 18281 2 bluetooth 180153 13 btusb,rfcomm,bnep parport_pc 32866 0 ppdev 17113 0 binfmt_misc 17540 1 mac_hid 13253 0 lib80211_crypt_tkip 17390 0 wl 2568249 0 lib80211 14381 2 lib80211_crypt_tkip,wl lp 17799 0 parport 46562 3 parport_pc,ppdev,lp vesafb 13844 1 usb_storage 49198 1 ums_realtek wmi 19256 1 dell_wmi video 19596 0 atl1c 41718 0
