296
Is there any difference between
sudo apt-get purge <package-name>
and
sudo apt-get remove <package-name>
I often see people recommend one or the other.
In other words, what does apt-get purge remove that apt-get remove doesn't?
essential
  • 107
Seth
  • 59,332
As the man apt-get page says:
remove - remove is identical to install except that packages are removed instead of installed. Note that removing a package leaves its configuration files on the system. If a plus sign is appended to the package name (with no intervening space), the identified package will be installed instead of removed.
purge - purge is identical to remove except that packages are removed and purged (any configuration files are deleted too).
This of course, does not apply to packages that hold configuration files inside the user's home folder (e.g. /home/Ubuntu_User), these files will not be touched ( Why does "Purge" not remove everything related to an app? )
So for example, if you were to purge Chrome, Firefox, Kodi, or any other that holds some configuration files inside your /home folder, these configuration files will stay there.
On the other hand, if you were to install Apache, squid, MySQL, or any other services similar that save their configuration files in /etc, these configuration files will be deleted if you use purge.
Rishon_JR
  • 1,028
Luis Alvarado
  • 216,643
47
An excerpt from my answer on another question:
  • apt-get remove packagename
    will remove the binaries, but not the configuration or data files of the package packagename.
  • apt-get purge packagename, or
    apt-get remove --purge packagename
    will remove about everything regarding the package packagename, [...]
    Particularly useful when you want to 'start all over' with an application because you messed up the configuration.
gertvdijk
  • 69,427
29
apt-get purge removes configuration files, while apt-get remove does not.
d a i s y
  • 5,551
moon.musick
  • 1,958
