So my Problem occurs as i already mentioned in my title after i tried to upgrad my old version. For no reason the upgrade broke of after the installation. Now i am not able to upgrade anything the upgrade manager is always closing when i am trying to open it.
Hope you guys can help,
with kind regards
Alvar
  • 17,038
You might be able to fix it but it will be slower and crash more often. The best thing is just to make a solid backup of all your files and start over with a fresh 12.04.
I had the same issue when upgrading to 11.10, I fixed it but it wasn't as good as a fresh 11.10
Linked question:
Alvar
  • 17,038
Open up a Terminal
write
sudo apt-get update
and
sudo apt-get upgrade
sudo apt-get dist-upgrade
if that fails try
sudo dpkg --configure -a
Also check if your sources.list is set to precise instead of oneiric at the end of each deb and deb-src line.
sudo gedit /etc/apt/sources.list
