Possible Duplicate:
How can I install software or packages without Internet (offline)?
I'm just beginner to linux operating system I have following doubts
1.Now i am using ubuntu 10.10 version i dont have net connection in my home So how can i install packages manually for ex: if me and my friend have same version and same hardware config
if he installed installed all packages in his laptop can i install all his packages by copy packages from his lap to mine ?? if there is a way then how to do it??
Thx guys in advance..... :)
Roshan
  • 123
You could copy the debs you need off his system out of /var/cache/apt/archives, but you'd need to be sure that you get all the dependencies for the debs you want. Then you'd install with dpkg -i. I'd say it's fairly likely that you may miss a package or two and end up with uninstallable packages, so if you're not sure what you're doing, I'd suggest not doing this.
One alternative, you could also use gdebi to install the debs once you copy them. gdebi will figure out what dependencies you need, dpkg will not until it tries the install, and apt can't install local files. gdebi is not installed by default, so you'd need to download it first.
mfisch
  • 3,693
So if you have the same packages as you friend do with same version of preparing system .
first you need to grab them from the location mentioned in previous answer . then place the packages in the same location in your pc .
then you can do the thing in two ways .
  1. sudo aptitude upgrade
  2. cd to the directory where you placed the packages and do like
sudo dpkg -i *.deb .
it will install all the packages . hope that helps .
Raja G
  • 105,327
  • 107
  • 262
  • 331
