19
I'm writing a script and I would like to pass the results from bc into a variable. I've declared 2 variables (var1 and var2) and have given them values. In my script I want to pass the results from bc into another variable say var3 so that I can work with var3 for other calculations. So far I have been able write the result to a file which is not what I'm looking for and also I've been able to echo the result in the terminal but I just want to pass the result to a variable at moment so that I can work with that variable.
echo "scale=2;$var1/var2" | bc
Eric Carvalho
  • 55,453
shaolin
  • 303
If you're using bash, you'd better use an here string instead of a pipe as in:
bc <<< "scale=2;$var1/$var2"
This will save you a subshell.
Then, to store the output of a command, use a command substitution:
answer=$(bc <<< "scale=2;$var1/$var2")
Edit.
If you want something even cooler than bc, here's dc (reverse polish calculator):
answer=$(dc <<< "2k $var1 $var2/p")
11
Command substitution stores the output of a command into a variable.
var3=$(echo "scale=2;$var1/$var2" | bc)
