Here is your solution :
#! /bin/bash
mkdir dir
for ((i=1;i<=25;i++)); do
printf 'x=%s\ny=4\n' "$i"
for ((j=50;j<=70;j++));do
t=$(bc <<< "scale=1; $j/10")
printf 'z=%s.1f\nw=4\n' "$t" > dir/diles_$i\_$t.txt
done
done
Explanation :
- Bash works only with integer, so you can't do your loop with a float / decimal (you see that I just use a division by 10 below)
- We use
bc command, which convert integers operation (a division for example) in order to get float; scale operator show how many decimal we want to have (here, 1 is suffisant in order to not have many 0, like bc -l do)
- we need to add a
\\ in the filename because it didn't take care of the i to name files ifnot
Also, I pointed that your 1st printf command just print result like that in the terminal, probably you would add them inside each file (instead of terminal display), so you must use the code below in this case :
#! /bin/bash
mkdir dir
printf 'x=%s\ny=4\n' "$i" > dir/diles_$i\_$t.txt
printf 'z=%s.1f\nw=4\n' "$t" >> dir/diles_$i\_$t.txt
done
done
NB : the >> operator or the 2nd printf command is important here (1st printf didn't care, depends only if you want to take care of previous data - >> -, or not - >), because if you use just a > operand, you would erase all previous data (so output of the 1st printf would be removed)
Sources :
