I followed this procedure to restore a previously exported list of packages in a new system. At the end of the procedure, after sudo apt-get dselect-upgrade -y I got this message:
[cut]lot of output, everything OK[cut]
/var/cache/apt/archives/libsensors4_1%3a3.3.1-2ubuntu1_i386.deb
/var/cache/apt/archives/gcc-4.4-base_4.4.7-1ubuntu2_amd64.deb
The full output is available on paste.ubuntu.com. /etc/sources.list content is also available here.
Then I typed again sudo apt-get dselect-upgrade -y. This is the error:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
libxslt1-dev:i386 : Depends: libxml2-dev:i386 (>= 2.6.26) but it is not installed
E: Unmet dependencies. Try using -f.
And trying to sudo apt-get -f install:
Correcting dependencies... Done
The following extra packages will be installed:
libxml2-dev:i386
The following NEW packages will be installed:
libxml2-dev:i386
0 upgraded, 1 newly installed, 0 to remove and 6 not upgraded.
5 not fully installed or removed.
Need to get 0 B/761 kB of archives.
After this operation, 2,206 kB of additional disk space will be used.
Do you want to continue [Y/n]?
(Reading database ... 372874 files and directories currently installed.)
Unpacking libxml2-dev:i386 (from .../libxml2-dev_2.7.8.dfsg-5.1ubuntu4.3_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/libxml2-dev_2.7.8.dfsg-5.1ubuntu4.3_i386.deb (--unpack):
'./usr/bin/xml2-config' is different from the same file on the system
Processing triggers for man-db ...
Other people had similar problem and I tried to follow this answer, but without being able to solve. Can you help me?
